Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
ok dumb question
Old Sep 18, 2011 | 01:11 PM
duramaxed's Avatar
Default ok dumb question
k so i am looking to get tires... what is the max size i can get on stock rims? and any suggestions im leaning tward some bfg all terrains... but wasnt sure hopeing to be able to get 33's or 35's on with full turning motion... is that possible?.
Old Sep 18, 2011 | 11:01 PM
2500HeavyDuty's Avatar
stock wheels an ride height 285/75/16 is tge biggest most people go.
i run 315/70/17's on H2 wheels, but i also hacked my fenders so i can tuck them lowered
Old Sep 21, 2011 | 11:22 PM
SgtKilroy's Avatar
You can fit 35's with some surgery, but I'd stay away from the BFG's. They wear out quickly.
Old Oct 12, 2011 | 06:17 PM
zbructo's Avatar
Heavy Duty is right you can tuck 285's fine trim for 35's. BFG I think make good tires. I had a set of All terrains last 85,000 and my Mud KM2's I have now are wearing good with 45,000 on them still have I'd say easy 75% tread. Just make sure to rotate and they will last.
Old Oct 12, 2011 | 10:42 PM
fireman-1781's Avatar
I have ran 285's and 31x12:50 there both really close but if you crank your tortion bars up you can fit 33's
They will rub the frame and the finderwell but not bad enough to worry about . As far as tire brand goes big are ok if your on flat terrain. Up here im the mountains there just to soft and don't last. Ive had them all best yet for me are cooper sst or just cooper st both run superb in snow and mud.
Old Oct 13, 2011 | 05:58 PM
zbructo's Avatar
Well on the 33's as far as a little rub is concerned it depends on the offset too of the rim mine I didn't crank up the torsion bars and they fit just fine only rub in reverse when crank the wheel over all the way very light rub. Avoid cranking on the torsion bars if can asking for future problems in doing so get some keys if wanting little more clearance.
Old Oct 14, 2011 | 02:58 AM
cranking does the same thing that keys do
Old Oct 14, 2011 | 06:46 PM
zbructo's Avatar
My bad actually yes if decide to crank the torsion bars try not to max out to avoid a bad alignment and suspension problems.
Old Oct 14, 2011 | 11:57 PM
anarchy61187's Avatar
my 1/2 ton has 33x12.5 on 15's and they fit fine but my keys are turned up a bit and I lifted the rear about 1.5 inch to level it out with a small load. but different gen trucks tho.
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
Josh_L
Apr 12, 2015 12:12 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
