Key trick
Old Sep 17, 2011 | 08:11 AM
jd5's Avatar
jd5
Default Key trick
So I tried the key trick, I turned it to on position and back off 3 times within 5 seconds and my odometer said "p done" after the third turn....what does that mean??
Old Sep 17, 2011 | 08:25 AM
turbo20psi's Avatar
Pdone is the snanning of the PCM in the truck. You should have saw Pdone twice.If not do it again and wait until you see it twice,there maybe code stored.
Old Sep 17, 2011 | 08:41 AM
jd5's Avatar
jd5
thanks for the reply, but I just did it again and p done stays up for about 2 seconds and then it goes to my regular odometer reading. I waited for a minute and it never changed from the regular odometer reading? so I mean is that a good thing that nothing showed up?
Old Sep 17, 2011 | 08:45 AM
turbo20psi's Avatar
Yep you are good. If you wanted you could go to advance auto and there do a scan for free.
Are you having any problems?
Old Sep 17, 2011 | 10:17 AM
Russ Roth's Avatar
That second Pdone only seems to have started sometime in the '02 year. My very early '01 does not do it.
Old Sep 17, 2011 | 05:14 PM
turbo20psi's Avatar
That's weird mine does but its a 01.5..
Old Sep 17, 2011 | 07:47 PM
Russ Roth's Avatar
That's probably the change then.
Mac1997
Jul 13, 2015 05:08 AM
thurobred1320
May 5, 2015 09:26 PM
1997silverado
Feb 13, 2015 08:11 AM
Baradium
Nov 21, 2014 08:20 AM
