5.9 power loss at 50 mph+
Old Sep 16, 2011 | 01:12 PM
jimjames's Avatar
Default 5.9 power loss at 50 mph+
Dear Bombers,
After driving my truck for twenty minutes, my 5.9 looses power at high revs and must be down shifted and reved up. Then it drives fine for a while. I've changed the fuel filter, lift pump, drained the tank and still having the problem.
JimJames
Old Sep 16, 2011 | 02:49 PM
empty wallet's Avatar
Need more info on your truck... auto trans? mods? fuel pressure? If you don't downshift and floor it does the pedal just not respond? Could be APPS (throttle position sensor) do you know how to use the key trick and check for codes?
Old Sep 16, 2011 | 04:13 PM
jimjames's Avatar
Dear empty wallet (diesel will do that to ya),
If I floor it the petal will not respond, until I down shift. I had a code indicating the lift pump problem. But new lift pump didn't solve problem. Fuel presure haven't checked (don't know how). The truck is a Ex-FedEx truck, we intend to make into a food truck. But the truck has other ideas. When running the truck humms, beautifully down the road. Oh the tranny is a Spicer 5 speed, fairly bullet proof I'd think.
My gal Nancy and I would appreciate any help you can offer, Thanks for the reply.
JimJames
Old Sep 18, 2011 | 12:17 AM
RanchhandTCR's Avatar
Sounds like what empty wallet said a throttel positioning sensor. Fuel pressure between the lift pump and transfer should be around 17 psi or so. Good luck.
Old Sep 18, 2011 | 09:44 AM
jimjames's Avatar
Default Will Check It!
Thanks Ace,
That's a cool sniper system, bull barrel, bipod, synth stock, awsome scope. Hell on ground hogs, huh?
JimJames
Old Sep 18, 2011 | 07:29 PM
Originally Posted by jimjames
Thanks Ace,
JimJames
Its hell on any varmint that gets in the way of the bullet. Remington 700 22-250. If they run they will only die tired Farthest shot is 523 yards on a prarie dog and nailed a yote last month at 430 yards on a the run my uncle missed him. I stole his yote.
wiremanWelder357
May 25, 2015 09:10 PM
Bighouse
Apr 9, 2015 06:51 PM
krg3590
Mar 15, 2015 08:57 AM
Cougdiesel
Oct 19, 2014 10:09 PM
