01 cummins electrical
Old Sep 16, 2011 | 07:19 AM
hoagdiesel's Avatar
Default 01 cummins electrical
I have an 01 cummins w/6 speed. decided it don't like to run. while driving once warm the tach jumps then dies. checked out fuel pressure and was at 12 psi so since at low side of spec I replaced. didn't fix. plugged in Genisis and found crank sensor issue(01 does not have) so while talking with Cummins we decided to replace the cam sensor. Still does. cleaned all grounds and power wires. still dies. next step pump. sent in and had rebuilt. paper work came back and said bad head, rotor and controler. installed and still problem. I am thinking ECM but would like to know other thoughts.
Old Sep 16, 2011 | 08:00 AM
mysterync's Avatar
Default Re: 01 cummins electrical
Um..not to be a jerk, but I've got a 01 truck that is in the shop right now that just got a crank sensor...vp trucks have crank sensors.....
Old Sep 16, 2011 | 08:16 AM
hoagdiesel's Avatar
not taking it personal. my dad could not find sensor and the cummins shop that I deal with said that they do not have one. I will have to look for myself tonight when I get home
Old Sep 16, 2011 | 08:24 AM
mysterync's Avatar
It's behind the starter. Advance, napa both keep some in stock around here. I'd net that was it the whole time. If that doesn't work run the pump independently of the ecm/pcm and see if the issues persist.
Old Sep 16, 2011 | 08:33 AM
hoagdiesel's Avatar
how would I run pump independently
Old Sep 16, 2011 | 08:47 AM
empty wallet's Avatar
I wouldn't that can be dangerous and bad for the pump... He is right, do the crank sensor. My '00 had it go, and other than my brother breaking it off in my block is was easy fix
And I got my sensor from Cummins, I just don't trust what napa sells, especially after I got a window motor that only lasted a friggin year from them.
Last edited by empty wallet; Sep 16, 2011 at 08:47 AM. Reason: Automerged Doublepost
Old Sep 16, 2011 | 09:00 AM
mysterync's Avatar
Is that why I've have four tools from Bosch that allow me to run the pump independently? Give me a few minutes and ill post a video.
It's not a good idea to do this without the tool tho.
Old Sep 16, 2011 | 09:03 AM
mysterync's Avatar
Old Sep 16, 2011 | 09:19 AM
hoagdiesel's Avatar
Dad just got off the phone with cummins and with the engine # they said that all the engine timing is controlled by the cam sensor and it has a plastic plug where the sensor should be. this is what he found when examined. also thanks for the pics of the tooling.
Old Sep 16, 2011 | 09:31 AM
mysterync's Avatar
That's a first for sure. Did you take the starter off to see the plug? What is you esn and cpl #?we work on these trucks every day, and as I said there is a 01 6spd here now that just got a crank sensor. You must have a 1 in million.
