Fuel Pressure question
Old Sep 15, 2011 | 07:58 PM
colinheitshusen's Avatar
Default Fuel Pressure question
So i picked up my new truck last saturday and have drivin it quite a bit and have come to notice that when driving at a constant speed around 55-65 the fuel pressure guage )that was installed before me owning it) sort of bobbles around 10-12 psi. and will run about 13 at acceleration and if it isnt bobbling around it will sit around 9. the truck does not have a fass or airdog. Ive looked at the guages and the installation is awful. So im wondering if it could be that the guage is screwy, if its a pressure problem, or if its nothing to worry about.
Old Sep 15, 2011 | 08:05 PM
turbo20psi's Avatar
It is normal for the gauge to move around a little.That beening said as long as there is a snubber or needle valve in line the gauge should be ok.
The pulses from the VP44(injection pump) are very strong.
Old Sep 15, 2011 | 08:27 PM
alright, i just dont want to have to worry about it till i can get an air dog in it. thanks.
Old Sep 15, 2011 | 08:31 PM
turbo20psi's Avatar
No problem you can put a price quote on here when you are ready to buy.
Price Quote - Request A Price - Diesel Bombers
The sponsor's on here are top notch and will back there product.
Old Sep 15, 2011 | 08:41 PM
Thanks a bunch!
Old Sep 16, 2011 | 01:50 PM
brentm@fassride.com's Avatar
VP 44 will need 16-18 psi if you drop more than 2 or 3 pounds under WOT you may be running out of fuel. What kind of power adders do you have currently?
Old Sep 16, 2011 | 02:44 PM
empty wallet's Avatar
Your pressure is just too low, aftermarket pusher should fix it. You want 18psi at idle. If you are regularly seeing 9 you've drastically cut the lifetime of your vp44, sorry to say.
Old Sep 16, 2011 | 03:12 PM
the truck is basically stock but it has some accel diesel chip with a 35 horse stage and 65 horse stage. ive turned it up maybe 5 time sinces saturday otherwise ive been running it stock. dont really need an issue right away. and not very thrilled about having to put 600 bucks or so into a pusher when i need to put tires on also.
Brent think you could PM me a price for a 90gph fass?
Last edited by colinheitshusen; Sep 16, 2011 at 03:12 PM. Reason: Automerged Doublepost
Old Oct 8, 2011 | 05:09 AM
chadcycle 2500's Avatar
check your fuel filter also,but if you have the stock carter lift pump pretty normal reading,but you want to stay above 10 psi @ wot. Be sure to use some kind of additive/lube for the vp44
Old Oct 9, 2011 | 03:23 PM
TTCummins's Avatar
check fuel filter
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
scottxmorris
Oct 8, 2014 02:14 PM
cummins Pride
Oct 6, 2014 11:28 AM
