Less smoke more power
Old Sep 15, 2011 | 05:29 PM
kieron_kohlmann's Avatar
Default Less smoke more power
When I hit the throttle from a stop, The truck just lays a thick blanket of smoke. how can i make it accelerate faster, with out the side affect of smoke?
Old Sep 15, 2011 | 07:08 PM
cumminspwr11's Avatar
fine tune your afc, it takes lots of tinkering to get it where you want it, you probably have it too soft right, the little amount of boost at low end is pushing the foot all the way forward too soon. you can tighten the afc spring up some and also move the afc housing forward and backward to get it where you like it
Old Sep 15, 2011 | 07:31 PM
Which way should I start moving? Forward? or Back? how do i adjust the spring? I haven't messed with P-pumps too much.
Old Sep 15, 2011 | 09:19 PM
turbo2332's Avatar
you could take some rack travel out of the pump by sliding your plate back
Old Sep 15, 2011 | 09:39 PM
mysterync's Avatar
Default Re: Less smoke more power
I would use shop air to adjust the afc according and adjust according to boost sounds like you afc is real post or you have a boost leak
Old Sep 16, 2011 | 01:27 AM
ya take the afc housing off and use a blower nozzle, the "star wheel" is just a nut on a threaded shaft lefty tighty, righty loosely, i believe the closer you move it too the front of the truck the tighter it is
Old Sep 16, 2011 | 04:47 PM
kansas_first_gen's Avatar
buy the stiffer spring from pure diesel power, tune the afc with shop air so it doesnt move until about 20 psi, and move your plate around until your topend fuel and spoolup fuel like each other
Timglow546
8
Jun 3, 2015 10:13 PM
wiremanWelder357
May 25, 2015 09:10 PM
shawnecarter
May 11, 2015 02:47 AM
