Codes p0602,p1693
Old Sep 15, 2011 | 10:57 AM
BACONBITSFORU's Avatar
Default Codes p0602,p1693
So I read on a post how to do the key code trick on my 2001. I tried it out just for the heck of it. I gave me 2 codes, P0602 and P1693. I also ran the code check on my insight... Same thing but when I plug the smarty in no codes on it... I have no check eng light but I do have the abs and brake light on all the time and it is for the right front abs sensor... ( know this because it got ripped in two some how. Any one know what these codes mean. The truck runs fine and has no real problems. Thanks
Old Sep 15, 2011 | 11:48 AM
empty wallet's Avatar
ECM fueling calibaration error.
Old Sep 15, 2011 | 01:58 PM
So what money needs to be send or screws need to be tightened
Old Sep 15, 2011 | 04:21 PM
What I found says "ECM internal fault condition detected"
I also see on some other forums guys saying their smarty is setting that code off, do you have a smarty? If you don't go see if the stealership can re flash the ecm. I know nothing about this to be honest, just sharing what I could dig up, which wasn't much
Old Sep 15, 2011 | 04:26 PM
turbo20psi's Avatar
When load the smarty in you will get that code.
Have you updated the smarty?
Old Sep 15, 2011 | 06:55 PM
Ok I updated the smarty and took the truck back to stock... Also cleared the codes so I'll see if they come back up if not then it's the smarty and that's ok! I think the boost fooler was tripping it out. Of any thing it will slow my bat out of hell self down
Old Sep 16, 2011 | 10:18 PM
it was the smarty... truck ran like a turd with out it so i put it back on
Old Sep 17, 2011 | 07:21 AM
turbo20psi's Avatar
I think there is a software update on smartys sit to get rid of that code.
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
