Starting problems
Old Sep 15, 2011 | 10:51 AM
95cummins4x4's Avatar
Default Starting problems
I went to start my truck this morning and it tried to turn over then immediatly quit and wouldnt even click when i turn it over my batteries are brand new and i tested them they have 13 volts so theyre good, i had a similar thing happen to me about a month ago because the previous owner installed a new starter but jimmy rigged the wires and one fell out so i got new connectors and tightned those down really good so thats not the problem either its not even making that distinct noise when you turn over the key im really lost any thoughts are appretiated i need it for work tommorow its a 95 4x4 c.t.d
thanks everyone
Old Sep 15, 2011 | 07:40 PM
aguilar_15's Avatar
I think its your batteries. Something isn't making a good contact or ground. Unless its the alt but I doubt it.
Old Sep 15, 2011 | 08:07 PM
mylilpwny's Avatar
check all connections .. never hurts to check multiple times ... might miss something only going over once ... have a similar prob in my 97 and it was my batt terminal were the wire splits to the starter .. bad connection inside .. i put new terminals on the cables and never had a problem again
Old Sep 15, 2011 | 10:04 PM
i am gonna check every connection i don't think its the alternator it was driving fine left it over night went to start it and it clicked once then stopped and wouldn't make that noise when you turn over the key to start it i then tried to turn it over again and there was no usual noise i get when i turn the key over before i crank it up i just replaced batteries two weeks ago and battery cables and new terminals?? sucks hitching rides to work
Old Sep 16, 2011 | 01:14 PM
monster12valve's Avatar
check the relay and fuses?
Old Sep 16, 2011 | 01:29 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Try jumping the solenoid on the starter... That will at least tell you if your starter motor works or not! If it starts that way then start chasing wires
Old Sep 16, 2011 | 08:52 PM
im new to this so how do i jump the solenoid in the starter??
Old Sep 16, 2011 | 09:43 PM
aguilar_15's Avatar
I think you just hook up the batteries to the starter terminals and see if it kicks out and rotates like it would if it were turning the engine over. I had this happen to me once and it turned out to be a fuse in the fuse box located in the engine bay. Can't remember the number but it should say on the lid which is the relay for the starter.
Old Sep 18, 2011 | 06:51 PM
i jumped the starter i think it sparked then made a noise like it was working so i think one of the connections went bad
dskewes14
Sep 14, 2015 09:19 AM
GasItOut
35
Jul 22, 2015 01:11 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
JRB1960
Dec 1, 2014 09:24 PM
angies04
Sep 29, 2014 04:11 PM
