weird fueling issue, with codes
Old Sep 14, 2011 | 09:41 PM
pavemen's Avatar
Default weird fueling issue, with codes
99 CTD with 279,000 miles. Unknown if VP44 has been replaced previously (I am 4th owner). Has had Ottomind box on it for a while when I had bought it 30k ago.
Recently it started running up to 1700 RPM all in its own. No matter what I do with the throttle, it sticks there then goes back to idle/pedal position all on its own. If it is doing it and I turn off the truck, it starts up fine, but immediately goes back to the 1700 RPM regardless of pedal position. If it happens on the highway, it can happen around 1800-2000 RPM. So far, RPMs have settled after 20-60 seconds.
Once the RPMs run up, it throws P0252 and P0253. Its also thrown P0251 once as well. No other codes.
I checked APPS voltage and it is fine across the pedal range, I reset the APPS, adjusted the voltage to label specs. Alternator and batteries replaced 18 months ago. Starts fine and no obvious electrical issues.
Fuel pressure is 12-14 psi in all cases. Filter is dirty, but not clogged.
When the RPMs go up on their own, the throttle and cruise cables are loose, so nothing weird there. Also, my scan tool TPS readings do NOT change when the RPMs run up on their own.
I am not sure if the Ottomind is going bad (will check by unplugging the box) or if it is the VP44 or the ECM.
I have not found any reports of this behavior before so I am lost. I can't afford to buy a VP44 if that is not the problem.
Old Sep 14, 2011 | 09:46 PM
Whit's Avatar
Site Mascot
sounds like the VP to me
Old Sep 14, 2011 | 09:51 PM
pavemen's Avatar
So have you seen/heard of this behavior before? Its just strange that I can't find any info on it. Thanks for the feedback
Old Sep 14, 2011 | 10:17 PM
mysterync's Avatar
Default Re: weird fueling issue, with codes
It's hard to know without running pump in standalone. It will eliminate the trucks electronics. If the problem continues its a pump issue.
Old Sep 20, 2011 | 04:11 PM
pavemen's Avatar
So I spent some time today diagnosing the Ottomind module that is part of the Banks Power Pack. It looks like the module is going bad as disconnecting the pump wire calms it down.
I have unplugged the power pack harness from the main harness and while I don't ahve any gauge any longer, the truck appears to be running fine. I won't have the same drive-ability as with the module, but it works!
Will be sending the unit back to Banks to see if it can be repaired.
Old Sep 20, 2011 | 05:35 PM
mysterync's Avatar
I would reground the Ottomind 90% of the time it will solve your issues.
Daniel Leipart
Jun 28, 2015 02:42 PM
CharlestonFF
Chevy/GMC Duramax 01-04 LB7
Jun 24, 2015 10:02 PM
pcredneck03
Mar 22, 2015 05:51 PM
big tan snorkel
15
Dec 17, 2014 05:04 PM
Adam65
Nov 22, 2014 11:58 PM
