vacuum wastegate question??
Old Sep 14, 2011 | 08:48 PM
cthomas7192's Avatar
Default vacuum wastegate question??
Should the bar on the wastegate move on its own when your driving or what im pretty new to 6.5L so i really dont know. Also i plan on buying the turbo master boost controller form heath diesel sometime soon but until then i want to make sure everything is working right.
Thanks
Old Sep 14, 2011 | 10:46 PM
ssgstank's Avatar
Yes it is, that's how it controls the amount of boost.
Old Sep 15, 2011 | 08:30 AM
right thats what i thought i think mine might be jacked up just means i will have to speed up the buying process
Old Sep 15, 2011 | 04:53 PM
ebarresi5894's Avatar
the turbo master is 110% worth buying. that vaccum gives you like 3-5 psi, heath can give you at least 10
Old Sep 16, 2011 | 08:26 AM
oh very nice how hard is the install im sure it cant be hard
Old Sep 16, 2011 | 08:39 AM
it takes like 20 mins. you have to take off the air box and thats really it. watch out for the bolts on the heat shield on the turbo, spray them down they could break
Old Sep 16, 2011 | 10:54 AM
do i need the vacum pump elimination belt??
Also if i wire the wastegate shut what exactly does that do??
Last edited by cthomas7192; Sep 16, 2011 at 10:54 AM. Reason: Automerged Doublepost
Old Sep 16, 2011 | 09:59 PM
no you dont, what i did was took the bottom half off the vaccum pump so it runs as an idler, and wiring the wastegate shut is a good way to grenade your motor. it over boosts the motor beyond belief. i wouldnt do it!!
Old Sep 17, 2011 | 08:36 AM
yea i will not be doing that but will be buying the turbo master in a few days and also ive been looking to get mabey the kojo tune but i cant find it anywhere i search?
Old Sep 18, 2011 | 08:55 PM
get the max-e-tork from heath, anything heath sells is usually top product for the 6.5
they know their stuff over there
