96' front axle leaking
Old Sep 14, 2011 | 04:22 PM
usmc0311's Avatar
Default 96' front axle leaking
Hello guys! Im new to this diesel stuff. So just bare with me. Have a 96' 2500. Geared 3.54 and both the driver and passenger seals are both leaking. And do you have to drops the axle to change thoses seals?
Old Sep 14, 2011 | 04:44 PM
dezzrats's Avatar
Use this link, should tell you everything you need.
Front Axle Tech
Old Sep 14, 2011 | 04:49 PM
usmc0311's Avatar
Thanks man!!
Old Sep 14, 2011 | 08:22 PM
dezzrats's Avatar
That's the reference I used when I jacked up the drivers side axle seal when I did ball joints.
It is a major pain to do the passenger side seal but do it all when you break it down. The Dana 60 in the front of a Dodge is a special animal because of the disconnect on the passenger side so if you have worked on other Dana front axles as I have, be ready to re-learn a few things.
Good luck, and post up if you get stuck, and if you learn any new tricks post them up also.
Old Sep 15, 2011 | 12:46 AM
huntingguy's Avatar
If you have a cummins shop around i would see how much they would charge to do. Mine was a bear. I had to take a blow torch to it to break some of the bolts loose after breaking two braker bars. It was a lot harder than I was expecting.
Old Sep 15, 2011 | 03:10 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 on the passenger side The drivers side axle slides right out and its cake!! The passenger side axle is held in by a c clip because its a two piece shaft.... Not fun
Old Sep 16, 2011 | 02:08 PM
usmc0311's Avatar
Here is the update, got all the gusts out of the axle. and now just trien to figure out the best way to take them out! and i totally agree with ya'll. Pain in the butt!
Old Sep 20, 2011 | 11:45 AM
1AMatt's Avatar
So how did you make out?? Any luck over the weekend??
Old Sep 20, 2011 | 03:10 PM
dezzrats's Avatar
Get the good seals from Spicer! and get a couple of extras. I killed the first one I did on the passenger side.
Old Sep 20, 2011 | 03:31 PM
dennhop's Avatar
I absolutely hate the passenger side axle seal...I think I destroyed about 3 of them before I finally got one seated. ended up giving up, and went out and bought a 6 ft long piece of allthread, and a huge socket-don't even remember what size it was, to fit the seal, to drive it in. And even then, it was a PITA. Plus, on one side, my hub was rusted to the outer spindle, so I had to take that in to get it pressed off...
