Turbo Keeps Shutting Off - WHAT!
Old Sep 13, 2011 | 10:12 PM
boneill's Avatar
Default Turbo Keeps Shutting Off - WHAT!
I have an 04 Dodge Cummins TD with Bully Dog. As I accelerate or if I am towing, the turbo will hit 16PSI then shut off, losing power and spitting black smoke. If I take my foot off the pedal it will come back and I can accelerate with turbo again, but as soon as it hits 16psi it shuts off again. The exhaust temp is only about 1100, and engine temp is good.
What could it be?
Old Sep 13, 2011 | 10:47 PM
ISXdr's Avatar
Sounds like ECM is defueling. Dont know much about BD. Do they have safeties built in that will defuel under high exh temps, coolant temps ect? Could be boost sensor malfunction also.
Old Sep 14, 2011 | 08:41 AM
dangerous1965's Avatar
When you say shutting off you mean boost drops to zero? Check all your boots and intercooler! Power brake it and listen for a boost leak.
Old Sep 14, 2011 | 01:26 PM
cummins army's Avatar
sounds like a boost leak to me follow what dangerous said and you should figure it out quick
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
