should i change tranny fluid?
Old Sep 12, 2011 | 09:47 PM
mike12321's Avatar
Default should i change tranny fluid?
so i just bought a wrecked 99 and ive been slowly puttin it back together. i just took it for the first test drive and the tranny shifts a little weird. it wont shift unless i let off the throttle. im going to put a governor pressure solenoid and sensor in it and adjust the tv cable. but i was wonderin should i change the fluid, it has 191,xxx on it and it looks kinda scary
thanks mike
Old Sep 13, 2011 | 01:20 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Just install a Stage VI Suncoast Just kiddin! But if it looks scary you can try changin it. You need ATF +4 for your trans I believe
Old Sep 13, 2011 | 01:35 PM
01quadcab's Avatar
weather you change it or not if it's going to go out it will. I would change it myself.
Old Sep 13, 2011 | 02:06 PM
NadirPoint's Avatar
I think you have to pull the pan the replace those parts, so it' gonna get at least a fresh gallon to start with, right?
Old Sep 13, 2011 | 02:12 PM
1AMatt's Avatar
For some reason 6 quarts is sticking in my head when you drop the pan??? I could be completely wrong though
Old Sep 13, 2011 | 02:51 PM
NadirPoint's Avatar
Yes, that probably has a deep pan, so more like a gallon and a half.
Old Sep 13, 2011 | 05:10 PM
mike12321's Avatar
thanks guys i know it will go out im just tryin to bide time until i find a nv4500 and make mo money
Old Sep 15, 2011 | 01:10 PM
1AMatt's Avatar
Some fresh fluid and a filter change will probably buy you some time... Not a whole lot though
Old Sep 27, 2011 | 05:54 PM
gruffysram's Avatar
Check the adjustment on the bands,mine did exactly the same thing and I threw all the solenoids and pressure transducer at it and still did it!Adjusted the band and problem went away.Make life easier and install a drain plug on the trans if theres not one already it makes saving that expensive ATF+4 a lot easier.
Old Oct 7, 2011 | 08:43 PM
goldcummins's Avatar
yes change it for shure
