head gaskets changed now hard starting
Old Sep 12, 2011 | 08:33 PM
03powerstroker's Avatar
Default head gaskets changed now hard starting
I need help, i had the head gaskets changed in my 03 6.0 and now my truck is having issues starting. sounds like it is not getting fuel, changed the fuel pump and it started good for awhile and the started having problems later that day. What should i check now. It is not throwing any codes
Old Sep 13, 2011 | 08:21 AM
Mdub707's Avatar
What are you reading codes with? What else was done? Who did the work? What gaskets used? Why did you change the fuel pump? Just throwing parts at it? Did someone actually test fuel pressure? I would start there, but usually after the top end has all been apart, it takes a while to get the high pressure oil primed.
Old Sep 25, 2011 | 01:55 PM
03Powerstroke's Avatar
also check the FICM!!!!!! its really easy to test, just go to youtube and type in ficm test
Old Sep 26, 2011 | 10:58 PM
ava-7952886's Avatar
does it have hard start cold, hot or both? the high pressure oil rail could have a leak inside the valve cover if not put on carefully!! if you have an air compressor take out the icp sensor and hook an air line to it,, listen for an air leak from inside one or possibly both valve covers.
a high pressure oil problem will make it sound like a fuel issue cuz the injectors are driven off the high pressure oil
Last edited by ava-7952886; Sep 26, 2011 at 10:58 PM. Reason: Automerged Doublepost
Excursion73
Oct 27, 2015 05:21 PM
gwmeyer
May 14, 2015 12:46 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
91 7three
Jan 7, 2015 09:37 AM
Hardcorefx4
Oct 6, 2014 07:47 PM
