Truck wont stay at 70
Old Sep 12, 2011 | 06:47 AM
smokin-but-not-Broken04's Avatar
Default Truck wont stay at 70
When im going on a long trip after maybe 30 miles of driving my cruise will be set and all of a sudden my truck will start slowing down to like 60 I can step on the pedal all the way to the floor and it will barley start moving back to seventy not sure what's wrong any help will bbs appreciated its like I have no power after 60 or so
Old Sep 12, 2011 | 07:22 AM
Mdub707's Avatar
No codes? No other symptoms? Try reading codes with something other than your bullydog if you can, I could never get the right codes with them.
Old Sep 12, 2011 | 04:47 PM
Well I sold my bully dog I have a code reader ill try tonight and update ya
Old Sep 12, 2011 | 05:36 PM
Mdub707's Avatar
What code reader? Let us know if you find anything.
Old Sep 12, 2011 | 07:40 PM
bobfbigman's Avatar
When was the last time you changed the fuel filters?
Old Sep 13, 2011 | 12:33 AM
ntmdtr3fan's Avatar
Had a very similiar problem wiht ym truck about a year ago. Found that my Speed Sensor went bad. It would make my CC fall flat on its face like yours.
Old Sep 14, 2011 | 08:43 PM
I have a OBD code reader or scanner but I scanned the conifer and it showed no DTCs but it does have a little im monitor status and it shows egr and a mis ...and a ccm bubble not sure what that means
Also my abs light came on and wont go off just recently
Last edited by smokin-but-not-Broken04; Sep 14, 2011 at 08:43 PM. Reason: Automerged Doublepost
Old Sep 15, 2011 | 08:14 AM
Mdub707's Avatar
ABS light is usually an easy fix, more often than not it's just the wheel sensor. it's located on the top of the rear diff. Pull the sensor out and clean it, put it back in, should fix it. If not, it may need replacing, I've seen them physically damaged before too.
Sounds like you need to get a better code reader or have a shop scan it for you, those codes really don't help much. Your EGR code is because you have a delete. Since you have an early 04, it doesn't throw a check engine light like it will on late 04/s and 05-07 trucks.
Old Sep 15, 2011 | 04:04 PM
I wonder how much the speed sensor cost and if it would be worth trying .... the stupid truck drives perfect in town though ( which is too work and home for me ) so im not sure as far as the ABS I kinda figured it was the sensor but I didn't know you could clean it so I appreciate that it might save me some money!
Old Sep 15, 2011 | 09:28 PM
ntmdtr3fan's Avatar
Speed Sensors run about $95 at Ford.
