Is bypassing fuel heater bad?
Old Sep 11, 2011 | 10:00 PM
douger0500's Avatar
Default Is bypassing fuel heater bad?
just wondering? any serious drawbacks?
Old Sep 11, 2011 | 10:08 PM
mysterync's Avatar
Default Re: Is bypassing fuel heater bad?
Nope, you won't see any effect besides the air not entering the fuel system. Very easy and very fast mod that is a must if the heater leaks. You can get a kit with a new o ring and strainer.
Old Sep 11, 2011 | 10:22 PM
douger0500's Avatar
Good because me and gpa already super rigged that hoe. We drilled and tapped the brass connection on the fuel heater into the 90 degree hose fitting on the lift pump.
Worked really good.
About 90 percent killed my miss. I'm still thinking I have fueling issues. As soon as I hit boost it quites puffing crappy smoke straight to the good black kind.
Old Sep 11, 2011 | 10:28 PM
mysterync's Avatar
Should have just removed the fuel heater, and extension, and threaded the per filter back on. The you could still use factory parts to repair other issues. But if it works it works!
Old Sep 11, 2011 | 10:34 PM
douger0500's Avatar
I went straight to the lift pump using factory line and fittings that ran to heater. Should be able to use everything I already have.
Old Sep 12, 2011 | 11:33 AM
dezzrats's Avatar
I got rid of my heater when I installed a new strainer kit. No problems or issues. That stupid little heater could not have done anything for you anyway.
Old Sep 12, 2011 | 12:03 PM
NadirPoint's Avatar
My 1st Gen hasn't had a heater for 4 years and driven in -20 temps, no prob. Just make sure to use an anti-gel in the fuel if it gets below 17F° where you are.
Old Sep 12, 2011 | 04:43 PM
douger0500's Avatar
Well I turned the afc housing all the way up. So when it's under boost it doesn't miss. But if it's around 2200 rpms without a load misses like a hoochie momma!
Old Sep 12, 2011 | 06:37 PM
dezzrats's Avatar
This is the part number from the Fleetguard strainer Kit I used when I deleted my fuel heater on the '97..... FLEETGUARD p/n 384540000 S
Old Sep 25, 2011 | 03:22 PM
dennhop's Avatar
Running an Airdog 150, which bypasses the fuel heater altogether. Never had a problem with my 01, doubt I'll have one with my 97. You got to figure, there's a lot of cold fuel between the fuel heater and the injectors that's not heated anyway, so it's not really doing anything. The block heater does more than the fuel heater does.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
Mike H
Jan 25, 2015 10:08 AM
