Extremely Weird Electrical Issue
Old Sep 11, 2011 | 05:33 PM
wildbill's Avatar
Default Extremely Weird Electrical Issue
Friday morning, grid heater didn't run, started and idled sup par (stumbled, little white smoke). Yesterday morning, grid heater cycled, started and idled great. This morning, same as Friday morning.
What would make it run good when the grid heater cycles, and crappy when it doesn't cycle? Have I got a sensor or something shorted someplace? I'm usually pretty good at diagnosing things, but this has me wondering where to start. Anyone have a better guess than I do?
Old Sep 25, 2011 | 09:40 PM
bullet5.9's Avatar
I have the same exact problem with my truck. It only sputters in the morning when that stupid light doesn't come on. I think it might be a sensor or something. Did you happen to find anything out yet???
Old Sep 25, 2011 | 10:04 PM
wildbill's Avatar
I haven't yet. I'm thinking it's the integrated gasket (valve cover gasket), or the ECM. What you can try is unplug both injector harness connections, and ohm test the gasket (get's it and the injectors at the same time). If you find one that reads more than 1, write down which pair it is (front 3 are 1-3 back 3 are 4-6). After you do all 6, remove the valve cover, then the two nuts that hold the wires to the injector solenoid. If the injector tests less than 1, you got a bad gasket. Injector reads the same before and after, the solenoid is bad, and your in need of replacing the injector.
Note: if you got an ohm meter that can go to 20 or less, that's good as it'll have a fine read.
I'm praying that it's not the ECM.
Old Sep 27, 2011 | 12:34 PM
bullet5.9's Avatar
Mine only idols rough in the morning when that light doesnt come on. If the grid heat light comes on it idols like a top. Do you still think we have the same issue?
CharlestonFF
Chevy/GMC Duramax 01-04 LB7
Jun 24, 2015 10:02 PM
Squirt
Jun 19, 2015 12:40 PM
pcredneck03
Mar 22, 2015 05:51 PM
Adam65
Nov 22, 2014 11:58 PM
RollinDiesel
Oct 14, 2014 03:13 PM
