Abs 2003 dodge ram cummins
Old Sep 11, 2011 | 02:58 PM
Akitan600's Avatar
help Abs 2003 dodge ram cummins
Abs light and brake light light up !! hooked up a scantool LF sensor no circut, changed the sensor and cleared the code, dosent work. The light is back , all connectors cleaned!! Changed the speed sensor in the rear axle, cleaned the LF sensor. Tried to switch side with the cables,same code??Sometimes when i clear the code the light is off for a couple of minutes and then its back again when i turn the ignition on. Even changed the discs and pads any clue? please
Old Sep 13, 2011 | 02:42 PM
North Pole Hooker's Avatar
Exact same thing just happened on my '06. Anyone got any smart ideas? I'm at a loss, here, and it's MOOSE SEASON!!! Gonna drive it, anyway, and see what THAT gets me!
Old Sep 13, 2011 | 04:18 PM
chromedome's Avatar
I drove mine for a year that away before i fixed it. It is probably the hub and will cost about 600.00 to fix if you have someone else do the work. I had a friend of mine do the work and the hub cost 242.00 a piece I had him go ahead and replace both sides. Good Luck!!!
Old Sep 15, 2011 | 12:23 PM
Akitan600's Avatar
Ok! going to try changing hub
Done the disc, pads, connectors, sensors why not the hub
Bought one today with abs sensor
Weekend saved
Old Sep 16, 2011 | 01:59 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I would imagine it is just the sensor in that hub. Which I believe you can only get with the hub unfortunately These hubs can be pretty stubborn when it comes to taking them off so good luck
Old Nov 6, 2011 | 03:02 AM
Akitan600's Avatar
Hmm changed the hub with sensor no luck still light on
Old Nov 6, 2011 | 08:38 PM
steved's Avatar
Did you happen to change the opposite side...sometimes right and left depend on the point of view. You changed the other two, why not change the only one left?
Old Nov 7, 2011 | 09:22 AM
silverbullet1's Avatar
you dont have to buy the whole hub assembly to replace the abs sensor, i replaced my hubs, cuz they needed it after 200k. but the dealership sells the sensor by itself for around $60 and it takes about 10 minutes to replace. or you can buy the whole hub assembly for around $300. you may have nicked the sensor on installation, cuz i did that, bought a new sensor and noticed i damaged the orginal when i put it in, hope this was helpful
Old Nov 8, 2011 | 11:00 AM
1AMatt's Avatar
Did you have the truck scanned to see what was causing the light to be on? It will tell you the exact problem
Aug 13, 2015 11:50 AM
raude1
Apr 13, 2015 03:38 PM
elkmaniac
Oct 29, 2014 07:01 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
dieseldude03
For Sale
Oct 2, 2014 07:53 AM
