Just bought an 06
Old Sep 11, 2011 | 12:56 PM
edwardsfan99's Avatar
Default Just bought an 06
Just bought an 06 and took it in to get my Missouri state safety inspection done. The mechanic noted that he thought the rear main seal may be slightly leaking. Is this something that I can live with, or should I repair it ASAP? Also anyone know a round about figure to have it replaced, I'm no mechanic! Thanks!
Old Sep 11, 2011 | 05:25 PM
wildbill's Avatar
It's going to be a major task. All day job and it's gonna be some coin.
Old Sep 12, 2011 | 06:34 AM
Thanks Wild Bill, I will just have them do it!
Old Sep 12, 2011 | 09:02 AM
wildbill's Avatar
Old Sep 12, 2011 | 09:13 AM
K80's Avatar
K80
Hey Bill. I'm assuming this is a 2 peice seal and you are talking about oil pan to crank right? And what about the oil pan gasket. Does that need to be replaced when the pan is dropped? Might be stupid q's but just remembering from building gas jobs. Thanks.
Old Sep 12, 2011 | 10:05 AM
wildbill's Avatar
My leaks around the bell housing also. I removed the inspection cover, and didn't see any oil around the converter. So it's either coolant or fuel, cause I'm not using any oil. I never got around to checking bolt torque yet on the back of the pan. But I did on the front, and they were loose. What I thought was a front crank seal turned out to be loose bolts.
Old Sep 12, 2011 | 11:47 AM
Mine seems to have a little oil on the inspection cover, and the small shop where I took it for inspection is who mentioned the rear main seal. It isn't leaking on the driveway or anything, can I just leave it be until it gets worse?
Old Sep 12, 2011 | 12:46 PM
wildbill's Avatar
Does oil level seem to stay on the same spot on the stick? If so, I'd let er be until then. I've been going for the last 3 years with mine, oil level stays the same on the stick.
camoore
Jun 27, 2015 01:31 PM
tecklancer
Apr 9, 2015 08:16 AM
Bernardo153
Feb 24, 2015 10:13 PM
idahotexas7.3l
Nov 12, 2014 12:56 PM
