gauges
Old Sep 9, 2011 | 08:36 PM
chadcycle 2500's Avatar
Default gauges
I need a little coaching here,I'm finaly installing pyro, fuel pressure & boost gauges. I need input where to put the exhaust probe,in pipe after turbo,in cast iron outlet at turbo? Where is the best spot for boost gauge?I feel I need to watch where I drill so I don't leave chips in any thing that will get into engine like removing the part i drill& tap etc.
Old Sep 9, 2011 | 08:41 PM
mysterync's Avatar
Default Re: gauges
Boost bolt in intake manifold for boost, pyro in manifold before turbo, in back runner of manifold. Just don't install probe in exhaust manifold,vacuum the chips you can get then fire truck up. There will be less resistance through the hole in manifold, it will force the chips out the manifold instead of through the turbo.
Old Sep 9, 2011 | 08:53 PM
Default gauges
where does the boost bolt go I looked,by the intake elbow, can't find where to put it,The exhaust can't go in header pipe after turbo? Why? Thanks for speedy reply,John
Old Sep 9, 2011 | 09:05 PM
mysterync's Avatar
Default Re: gauges
John,
Boost bolt replaces any intake manifold bolt, not the elbow, the actual intake plate.
The reading you get from preturbo better reflect the exhaust gas temps. It's also much easier to get a leak free probe.
Old Sep 9, 2011 | 09:20 PM
Ok thanks foryour help
Old Sep 9, 2011 | 09:28 PM
mysterync's Avatar
Default Re: gauges
I usually go to the very front bolt on the left in this photo. I know this is a 12v truck but its just for reference. It's the bolt that's still in the intake. Honestly any of the bolts that are on the inner side should be fine. I'm putting some gauges in next week for a fellow, I'll post some pictures
Old Sep 10, 2011 | 08:41 PM
Ok thanks
Old Sep 12, 2011 | 06:59 AM
Made my own boost bolt,drilled out another bolt same size,cut off a barbed fitting& pressed it in a little jb weld to seal goood to go!! I put in glow shift yes heard mixed reveiws about them,so far they work fine. Thanks for help, JOHN
flainn
Oct 12, 2024 09:39 AM
Powerstroke36
Sep 6, 2015 02:41 PM
May 1, 2015 08:10 AM
Justin82
Price Quote - Request A Price
Apr 1, 2015 02:22 PM
carid
Diesel Bombers Sponsors
Dec 9, 2014 03:58 AM
