back brakes locking up?
Old Sep 9, 2011 | 10:20 AM
chaney2051's Avatar
Default back brakes locking up?
Trying to find a way to fix the problem of my back brakes locking up after truck is parked? I have changed wheel cyl and put new seals in rear.
Old Sep 9, 2011 | 11:05 AM
RollinCoal99's Avatar
are they drums or disks ?
Old Sep 9, 2011 | 11:06 AM
Kraemer's Avatar
proportioning valve
Old Sep 9, 2011 | 11:12 AM
chaney2051's Avatar
is there a good replacement to buy?
Old Sep 9, 2011 | 02:43 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I've always wondered why they do that But most Dodges with rear drums do it.
Old Sep 11, 2011 | 09:41 AM
AdirondackCoalRoller's Avatar
Is the proportioning valve adjustable?
My dually does it mostly after being parked for a short time.
After it is driven and warmed up the problem seems to dissapear.
I haven't had the rear drums off yet but it will be soon. Would be nice to fix problem before snow.
Old Sep 11, 2011 | 01:12 PM
chaney2051's Avatar
yea that is exactly what mine does.. drive it, park few few minutes-hours and then get back in it to take off and the lock up.. once i drive a very short distance they are fine again.. But its a real bad feeling when they do it at top of a hill you have to go down.
Old Sep 11, 2011 | 02:28 PM
Kraemer's Avatar
Default Re: back brakes locking up?
Factory proportion valve is not adjustable, but install an aftermarket adjustable one and all your problems will go away, after removing the factory 1 of course...
Sent from my ADR6300 using Tapatalk
Old Sep 11, 2011 | 03:12 PM
BACONBITSFORU's Avatar
My 2001 came with 4 wheel disk. So I've never had this problem
Old Sep 11, 2011 | 06:19 PM
Russ Roth's Avatar
Try adjusting them first before you do anything else. Mine used to do that until I discovered the self adjusters refuse to keep them tight enough under normal use. I have a long driveway I back into and I use the parking brake to stop several times backing in about once a week and that keeps them up. No more lockup in cold/wet weather unless I get lax about stopping with the parking brake for too long.
