cost of a rebuild
Old Sep 8, 2011 | 07:21 PM
94Cumminz's Avatar
Default cost of a rebuild
how much would it cost to rebuild and hold 450-500ish hp with out too many problems?
Old Sep 8, 2011 | 07:39 PM
monster12valve's Avatar
rebuild what?
Last edited by monster12valve; Sep 8, 2011 at 07:40 PM. Reason: Automerged Doublepost
Old Sep 9, 2011 | 08:29 AM
93_Fummins's Avatar
Engine: $1000-$10000 depending on what goodies you put in it
Transmission: $1000-$7500 depending on man/auto and what goodies you put in it
Driveline: $100-$1000 depending on what condition your current stuff is in
Making 500 hp isn't too hard or expensive, but MAINTAINING that horsepower for any sort of time is where the money starts burning fast. For instance, 500 hp is useless unless you can get it to the ground, which means a stronger clutch or better slushbox internals, then you want good tight driveline and the right gears and strong enough axles... Sometimes it's best to THINK backwards before you build, and only push your engine as far as what everything BEHIND it can handle. Then you'll spend less downtime with smoked clutches, broken input shafts, or blown head gaskets... Just my $0.02
Old Sep 9, 2011 | 10:28 AM
94Cumminz's Avatar
Motor blows oil out of the dip stick. If I could just get an overhaul for now would make me happy. So maybe 250-300 with the money I have at the moment.
Old Sep 9, 2011 | 11:36 AM
93_Fummins's Avatar
Sounds like blowby, which means new rings at the least with possibly a melted piston. If that's the case, you'll need a full overhaul kit with all the bearings and gaskets and possbily new pistons which tends to run roughly $750 or so for the kit....that's not including labor or additional machining cost. But, that's just my guess...
Old Sep 9, 2011 | 12:33 PM
Kraemer's Avatar
that like asking how much for a hooker?
search for a rebuild kit price, I reccomend a genuine Cummins kit. if your doing the work, labor is free, If you are not doing the work, call some shops get some quotes.
is the oil level high? visible blow by, is ccv blocked?
Old Sep 9, 2011 | 02:28 PM
94Cumminz's Avatar
i would have a shop do it but the ones around here seem to be high. they said they could do it for 5,000?
Old Sep 9, 2011 | 04:29 PM
Kraemer's Avatar
Default Re: cost of a rebuild
40 hours labor x's $100/ hour, plus parts and machine work. Sounds about right...
Sent from my ADR6300 using Tapatalk
Old Sep 9, 2011 | 05:18 PM
40 hours to disassemble and reassemble an engine?
5,000 should include removal, rebuild, basic machining reassemble, and reinstall. 5,000 for labor is SUPER HIGH!....atleast around here.
Last edited by monster12valve; Sep 9, 2011 at 05:18 PM. Reason: Automerged Doublepost
Old Sep 9, 2011 | 07:40 PM
Kraemer's Avatar
While where you live that may be true, but my labor rate is 150$/ hour, if you want Jose at bubba's truck shop to sweat all over your rig while "disassembling and reassembling" your engine that's fine, but if you want a factory trained technician to rebuild your engine with a warranty. You get what you pay for, too many hacks out there...
Edit: if you do the math I calculated, it was 4000$ for labor, 1000 for parts and machine, with a total of 5000
