Truck won't run
Old Sep 8, 2011 | 06:23 PM
Neibe's Avatar
Default Truck won't run
So here is what happened i started my truck up this morning and it ran rough but then it smoothed out. Went 100 feet down the road and died. Cranked it over finally got it started and got it off the road. Fuel gauge was on e put in 10 gallons pushed priming bulb several times cranked it over got it to start held pedal down ran a few seconds then died. Any ideas?
Old Sep 8, 2011 | 06:25 PM
H.R.D's Avatar
Did you bleed the fuel lines?
Old Sep 8, 2011 | 06:39 PM
Neibe's Avatar
I tried searching on here but I couldn't find how to do it. I loosened one of the lines on top of the injection pump pushed the priming bulb and no fuel came out also loosened the line on top of the injector and on fuel pushed priming bulb til i could hear a hissing. I clearly don't know what I'm doing.
Old Sep 8, 2011 | 07:34 PM
monster12valve's Avatar
tighten lines on inject pump.... fill the fuel filter full of fuel then put it back on. crack injections lines one at a time on injector side. once u see fuel spit out...tighten it and go onto the next one...she will start
Old Sep 9, 2011 | 04:11 AM
Neibe's Avatar
can i push the prime bulb to push the fuel or do i have to crank the starter?
Old Sep 9, 2011 | 06:23 AM
sunsetsky's Avatar
Site Sponsor - Black Cloud Diesel Performance
Did you get 'er goin?
Old Sep 9, 2011 | 05:25 PM
fill the fuel filter up manuelly... i find it to work alot better.
and prime the bulb.....i had to prime mine when i did my fuel lines atleast 100 times
Last edited by monster12valve; Sep 9, 2011 at 05:25 PM. Reason: Automerged Doublepost
Old Sep 10, 2011 | 03:24 PM
roll coal in cummins's Avatar
I changed my fuel filter truck wont start fuel is leaking out around the top of the cannister
its a 98 12v dodge cummins what should i do ?
Old Sep 10, 2011 | 04:43 PM
blazier18's Avatar
u dont have to prime (imo) just crack the lines like he said tighten them once fuel comes out and try to start it like that.
did u make sure the seal is seated? if not it wont have pressure and leak. take it back off check it real good and make sure its not cross threaded
Old Sep 10, 2011 | 04:48 PM
mysterync's Avatar
Default Re: Truck won't run
Remove fuel heater & replace rubber lines and remove fuel filter and check sealing surface?
