Belt problem.
Old Sep 8, 2011 | 03:41 PM
sjcoan's Avatar
Default Belt problem.
For some reason my truck keeps throwing the belt off, it has happened three or four times and usually wrecks the belt in the process. I dont see anything loose and dont hear or feel bad bearings. The only thing I can see is when I look at the crank pulley while its running it doesn't look like its spinning true. Any ideas fellas.
Old Sep 8, 2011 | 05:03 PM
aguilar_15's Avatar
Spinning true? Like it's crooked or something? If so then you might need to get a new one.
Old Sep 8, 2011 | 05:30 PM
sjcoan's Avatar
I took a look again and I think the crank pulley is alright but i did discover something as soon as I start the truck the part of the belt that goes around the fan pulley gets pushed back towards the engine so maybe I'll start there.
Old Sep 8, 2011 | 06:11 PM
aguilar_15's Avatar
Sounds good bud, good luck
Old Sep 8, 2011 | 07:50 PM
monster12valve's Avatar
i would def take a good look at the crank pulley.
Old Sep 8, 2011 | 08:29 PM
Billy D's Avatar
How bout your tensioner pulley
Old Sep 9, 2011 | 03:40 AM
97cummins's Avatar
I was about to mention the same thing.Some times when the roller on the tensioner wears, it will wear at kind of a slope where the belt will slide off the roller while the motor is running.I've seen this on the big rig cummins motors. good luck
Old Sep 12, 2011 | 08:06 PM
sjcoan's Avatar
Hey fellas thanks for the responses i think it figured it out i replaced the tensioner pulley after pulling fan water pump and inspecting everything.
Old Sep 13, 2011 | 12:35 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I have seen the tensioner pulley cause this before, as well as the crank pulley! Start with the tensioner its cheaper and easier
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Ironmanqb
Apr 4, 2015 10:27 PM
denpenn
Feb 11, 2015 11:29 PM
mnbf48
Jan 19, 2015 09:20 PM
