Diesel Power Products Visit - Diesel Power Products
Cummins DG speed Hunting
Old Sep 8, 2011 | 01:21 PM
pmmeeran's Avatar
Default Cummins DG speed Hunting
There are two Numbers DG sets are in service. The name plate details are
Make : Cummins
Model : 4BT3 – G3
Make : Newage Stamford
Model : UCI 22-4F
In one Generator the speed hunting problem is persisting.
While carrying out EFC calibration the following abnormalities are observed.
1. Idle speed correctly set at 1500 RPM. No hunting. ( EFC voltage 6.5 V)
2. With Droop setting at 30% ( 3% Droop) and gain at 50% when we changed over to Run mode the speed started to hunting. Increasing or decreasing the gain have no effect.
3. Once we increase the droop to more than 70% than the speed is constant.
4. After that the Circuit breaker closed and machine loaded up to 75% load. Then speed started to hunting but stabilized after some time.
5. If again the circuit was opened the speed is again started hunting and tripping at either low or high frequency.
What may be the problem. We changed governor control board ( P/N: 3044196) and EFC solenoid. No change in machine behavior.
Compare to other machine the only abnormality noticed is the No load EFC voltage is 6.5V in this machine and the other machine which is stable at no load the EFC voltage is 4.5V only.
1. Kindly advice what could be the problem.
2. Whether the problem is related with tuning. If it is because of tuning how to stabilize the machine in step-2. ( That is while changing from idle mode to run mode why the machine is not stable).
3. Why the machine is stable in idle mode and why it is hunting in no load run mode.
4. What is the difference between idle and run. Is it like open loop & close loop control.
5. What are the other parameters to be checked.
Regards
pmmeeran
Dertyd
24
Jun 7, 2015 02:45 PM
Taylor03
Jun 6, 2015 11:09 AM
raude1
Apr 13, 2015 03:38 PM
stephenthinnes
Dec 6, 2014 11:54 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
