Checking Injector Balance
Old Sep 7, 2011 | 11:33 AM
bwellard10's Avatar
Default Checking Injector Balance
I would like to check the balance on my '03 lb7. can anyone explain the process or link to one. Thanks for the help.
Old Sep 7, 2011 | 01:33 PM
PHPDiesel's Avatar
Sponsor
You cannot do it yourself without the proper scanning (read: actual diagnostic equipment) tools that support the Duramax drivetrain.
The balance rates (as they are displayed on a scan tool) are data that the PCM displays and uses to create a smooth idle.
Old Sep 7, 2011 | 01:39 PM
bwellard10's Avatar
Many thanks, what is a fair price to pay to have it checked out?
bwellard10
Old Sep 7, 2011 | 04:30 PM
PHPDiesel's Avatar
Sponsor
Typical shops (and I'd only recommend a dealer) will charge a minimum of an hour even though it takes 5 minutes with a warm truck to check the balance rates (and check out the fuel pressure regulator while it's there).
So whatever the shop charges per hour is what you'd be looking to spend at a maximum to just have those two things checked. You may be able to find a shop that will only charge you the time they have into it.
Old Sep 7, 2011 | 05:00 PM
bwellard10's Avatar
I have noticed an increased amount of smoke 25k miles after installing OEM remanded injectors. Could this be something other than injectors?
Old Sep 7, 2011 | 11:34 PM
BriteWhiteRam's Avatar
what colour of smoke? black or white?
Old Sep 8, 2011 | 12:34 AM
bwellard10's Avatar
Hello and thanks for the replies.
I bought the truck with bad injectors and it was puffing out white smoke for sure. Now it appears to be dark gray or black.
Thanks again
Old Sep 8, 2011 | 07:09 PM
have you checked your air filter or MAF sensor lately?
Old Sep 8, 2011 | 07:22 PM
bwellard10's Avatar
Air filter yes, MAF "No" , Easy stuff first right!
Old Sep 18, 2011 | 12:12 AM
Leftovahs's Avatar
bwellard10
shop i went today did it for FREE, I'M sure they knew i'd be back for mods tho.
