COMPUTER PROBLEM
Old Sep 7, 2011 | 08:12 AM
centexhogdogger's Avatar
Default COMPUTER PROBLEM
I have a 94 i need to know what all the computer runs.... only oil pressure and temp guage works.... help with any info...
Old Sep 7, 2011 | 09:21 AM
mysterync's Avatar
Default Re: COMPUTER PROBLEM
Auto trans, ic, shut off sol. Grid heater , to name the big ones. It runs quite a few functions actually.
Old Sep 7, 2011 | 04:08 PM
cumminspwr11's Avatar
it doesnt work the shut off sol. it will run the a/c, tack, alternator, maybe one or two other things, the trucks will run and drive without a computer just if its an auto it wouldnt shift od or lock up. you could also have a bad crank sensor, it will have all of the same problems as no computer
i ran my truck for a bit with a cooked computer, i have switches for od and lock up so i just had no ac for a few days
Old Sep 7, 2011 | 11:11 PM
mysterync's Avatar
heres the actual diagram. Your right the shut off solenoid isnt ran through the PCM, I was thinking the relays pulled hold power through the ASD side but it does not.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
edger57
Jan 17, 2015 01:21 PM
Dadslb7
Dec 9, 2014 11:05 PM
