Oil Leaking
Old Sep 6, 2011 | 06:19 AM
98.12.valve's Avatar
Default Oil Leaking
I know its a pretty common issue with the 12 valves but can anyone tell me where my 98 is leaking oil from and if there is any way to stop it, also should i check my oil on like a weekly basis due to the oil leak?
Old Sep 6, 2011 | 09:06 AM
South Tx Coal Roller's Avatar
It's probably coming from the valve covers. Can you give a bettter description, like the general area that the oil is coming from and how much oil is leaking out? It's a good idea the check your oil level weekly, leak or no leak.
Old Sep 6, 2011 | 11:33 AM
aguilar_15's Avatar
yup but maybe it's leakin from the motor/tranny mount? On breather tube but that doesn't usually leak it out
Old Sep 7, 2011 | 12:14 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Every 12 Valve leaks its a Dodge thing Do you have an idea where its comin from though? Front, back, left, right?
Old Sep 14, 2011 | 06:17 AM
it looks like its coming from the front passenger side of the motor but im not quite sure, its a slow leak and the whole undercairrage is covered in oil
Old Sep 14, 2011 | 07:04 AM
NadirPoint's Avatar
Default Oil Leaking
I would clean up the front of the engine with a powerwash/degreaser and see where the leak is. Could be KDP problem.
Old Sep 15, 2011 | 12:50 AM
huntingguy's Avatar
if it was on the drivers side i would say check the vacuum pump, I had a pretty good leak there. Can you take some pictures after you power wash it and drive it for a day or two?
Old Sep 16, 2011 | 06:25 AM
Next time i wash the truck ill clean up everything under the motor and see if i can find it, the guy that had the truck before me said he had all the leaks stopped but i dont think he did, also what kind of oil should i put in my truck like weight wise and everything because it needs some oil
Old Sep 16, 2011 | 08:56 AM
Valvoline Premium Blue, Delo 400, Rotella T, Mobil Delvac, all are 15w - 40 and will work fine.
Old Oct 1, 2011 | 01:00 PM
dmaxkiller's Avatar
hey i got my 97 thats leaking could u hit me with some info on what to look for with a leakin vac pump? mines coming from either the middle driver side or rear driver side.... i thought it might be my injector pump? is that common or easy fix?
