05 cr having all sorts of problems Help please
Old Sep 5, 2011 | 09:06 PM
*dixistar*'s Avatar
Default 05 cr having all sorts of problems Help please
I have a 05 cr dually with propane injection and thanks to the dodge dealership a new injection pump lift pump and all kinds of sensors i didnt need. The truck randomly dies and blacksmokes bad at idle
And wont pull itself up a hill. I am assuming its injectors but it cost 60 bucks a pop to check em. If anyone has some insight to this problem i could use the help. Thanks
Old Sep 5, 2011 | 09:34 PM
cummin_un_glued's Avatar
FormerVendor
sounds like injectors to me also with the black smoke and lack of power
Old Sep 6, 2011 | 08:30 AM
dangerous1965's Avatar
Boost leak? What numbers are you seeing? Clogged air filter, Turbo shot? Black smoke excessive fuel.
Old Sep 6, 2011 | 05:06 PM
*dixistar*'s Avatar
no codes checked the boost lines any way to check them on the truck besides taking each wire off
Old Sep 6, 2011 | 06:59 PM
Youngblood's Avatar
Rev your truck to like 3k and then let the RPm's come down, if they come down in steps then it's an injector problem. But aslong as they come down at a consistent rate i don't think it would be your injectors, i would start looking towards your turbo. faulty turbo will cause tons of smoke because it would ruin your fuel/air ratio, not too mention a big power loss.
Old Sep 6, 2011 | 07:26 PM
AHolt's Avatar
Most people seeing injector problems, are seeing white
smoke. I agree with above, turbo or boost leak.
Old Sep 6, 2011 | 07:50 PM
*dixistar*'s Avatar
Ok i noticed it surges bad down and it smokes bad at idle when it gets warm it wont start without either. It does surge when i rev it up. So if it is injectors were is the best place to get some maby 90horse or rebuilds. Thanks for your help
Old Sep 6, 2011 | 09:47 PM
FormerVendor
surge, no start, smoke = injector problem and i can get you 50 90 or 120hp rebuilds
Old Sep 7, 2011 | 12:42 PM
Youngblood's Avatar
No problem glad i could help, and Cummin_un_glued can help ya with the rebuild
moroza
Mar 29, 2015 05:37 PM
DODGEARMYGUY
Mar 3, 2015 11:40 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Tucker126
Jan 2, 2015 08:09 AM
yams
Audio Equipment/Electrical
Nov 29, 2014 09:25 PM
