ill effects of running NO thermostat?
Old Sep 5, 2011 | 01:27 AM
goobs's Avatar
Default ill effects of running NO thermostat?
are there any bad effects of running no thermostat?
Old Sep 6, 2011 | 04:00 PM
ebarresi5894's Avatar
you wont have heat in the winter
Old Sep 6, 2011 | 06:16 PM
2MuchJunk's Avatar
You need to run a thermostat. Thermostat does more than just warm the engine up it regulates the flow of water. If you don't run one you might not warm up to operating temp or you could over heat because the water will be flowing to fast through the radiator to get rid of the heat.
Old Sep 6, 2011 | 07:36 PM
wildbill's Avatar
Engine oil will sludge up also.
Wondering why your asking?
Old Sep 6, 2011 | 08:22 PM
2500HeavyDuty's Avatar
truck would overcool, it wouldn't reach operating temp, creating more wear on the engine.
Old Sep 6, 2011 | 08:37 PM
Red_Rattler's Avatar
High Tech Redneck
no, actually the truck will overheat... Like said it would bypass the rad so fast that it cant cool it
Old Sep 6, 2011 | 09:25 PM
turbostang7's Avatar
yep you remove the thermostat it will overheat bad!! takes longer at first to get up to temp but once its there it cannot cool the coolant because its moving to fast to cool it.
we have customers that try this all the time in their equipment, i have never seen one that it has actaully helped, it makes every one of them overheat.
Old Sep 7, 2011 | 09:01 AM
goobs's Avatar
hmm, i havent been running one for almost a year and have never over heated. even after driving 3 straight hours in texas heat multiple times. i have a new one to install just wasnt able to do it when i replaced the rad.
i plan on installing here soon though.
Dustin M
May 21, 2015 10:19 PM
realtrucksrattle
May 15, 2015 11:20 AM
Max713
Apr 17, 2015 01:18 AM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
carid
Jan 12, 2015 04:32 AM
