04' F350 5 Speed auto problem
Old Sep 4, 2011 | 11:52 PM
KILLERKEN's Avatar
Default 04' F350 5 Speed auto problem
I have a 04' F350 6.0 diesel with the 5 speed automatic. It was dropping out in the 3 to 4 shift. It was also taking a long time to shift into reverse & drive when put into gear. Had the trans rebuilt, still have problem. Trans shop said its not the trans. Ford dealer said theres nothing wrong, no codes and everything is in spec. Under hard acelleration it trys to shift into 4th but keeps trying to shift then drops out then trys again, it will keep doing this till you let off just a little on the throtle. Very rearly it will do it under regular driving. Driving me nuts and a fortune as no one has been able to solve the problem. HELP!
Old Sep 5, 2011 | 12:12 AM
mudweiser1's Avatar
are you running a power programmer on the truck?
Old Sep 5, 2011 | 10:44 AM
KILLERKEN's Avatar
Forgot, Yes Its a Super Chips programer.
Old Sep 5, 2011 | 10:50 AM
ntmdtr3fan's Avatar
Did the problem start before or after the superchips programer? I dont think the Superchips has a proper trans tune with it. I know SCT is the only tuner that safely tunes the trans of these Ford trucks. As youll hear from alot more you should toss the chip and get an SCT.
Old Sep 5, 2011 | 12:13 PM
KILLERKEN's Avatar
I just ordered a SCT LiveWire Tuner Programmer 6.0 Ford Powerstroke 310300297844, will try it out when it comes in. I hope it’s just the tuner, The trans was gone through 2 times, the solenoid pack was replaced 3 times. I have heard others complain about Super Chips but I had mine for the last 5 yrs with no problems till the end of last year. That’s why I had the trans rebuilt, figured with 135,000 miles it was starting to go.
Old Sep 5, 2011 | 05:39 PM
mudweiser1's Avatar
i just recentley ditched a bullydog triple dog programmer for the sct because I was experiencing trans issues. Truck would hold third to fourth shift until i backed out of the throttle... SCT installed...immediately fixed! I ordered custom tunes for the SCT from innovative and like there trans. programming a lot better than the canned tunes in the SCT. May want to look into it once you get your new programmer. Good luck, let us know what happens when you retune!
Old Sep 5, 2011 | 07:14 PM
KILLERKEN's Avatar
Thats the same thing mine was doing. It sucked, especialy when your about to blow away the kid in the Handa, & the old man in the BMW! Got to get out of it for it to shift. The worst part was I had the Trans rebuilt & they were honest with me & said everything still looked good, but was still $2000 bucks to go though it! I changed the fluid every spring as I plow all winter & Tow all summer with it. Hope it works out, we will see this week, I'll keep you all posted.
Old Sep 25, 2011 | 09:41 PM
mudweiser1's Avatar
Reprogrammed yet? I am really curious to know the out come.
Old Sep 26, 2011 | 07:37 AM
Mdub707's Avatar
Yeah, sounds like the exact same symptoms that my buddy had with his bullydog on his 04 6.0 too. SCT cured it.
The delay going into drive/reverse is scary though, damage may already be done there.
Old Sep 26, 2011 | 05:17 PM
KILLERKEN's Avatar
Yup, Just boosted the trans line pressures via the tuner & all is well with the world again. Just go home from Pittsburgh Raceway Park for out Brakett finals race. Towed our 11,000 lb enclosed trailer down & back with the cruise on. 65 mph up & down the hills with no problems. Ran the 65 hp Tow tune. SCT is the ****!
burndiesel
10
Feb 7, 2023 01:15 AM
Dertyd
24
Jun 7, 2015 02:45 PM
1ATony
1A Auto Parts
Dec 1, 2014 09:34 AM
flyers.nhl
Oct 31, 2014 04:33 AM
450r racer
Oct 19, 2014 11:38 PM
