5,000$ budget
Old Sep 4, 2011 | 11:10 PM
2000_fummins's Avatar
Default 5,000$ budget
I have a bone stock 12v an got about 5k to spend what would u do?
Old Sep 4, 2011 | 11:50 PM
stroker30's Avatar
Put stacks on it.
Old Sep 5, 2011 | 12:21 AM
BACONBITSFORU's Avatar
Lift pump injectors springs plate fuel pin auto or manual tranny?
Old Sep 5, 2011 | 01:33 AM
Fully built auto tranny
Old Sep 5, 2011 | 08:38 AM
Red_Rattler's Avatar
High Tech Redneck
What's your goals for the truck
Old Sep 5, 2011 | 09:14 AM
12vcummins96's Avatar
yes sir x2
Old Sep 5, 2011 | 09:29 AM
monster12valve's Avatar
Old Sep 5, 2011 | 09:59 AM
JDT's Avatar
JDT
Cam, Valve springs, head studs, injecotors, airdog or FASS pump, governor spring kit, intake and exhuast, hopefully gauges too? At least thats what I would do with $5000
Old Sep 5, 2011 | 11:02 AM
Hightech_Redneck's Avatar
you need a trans/clutch first off.... good quality gauges, 5x.012 injectors, hx40 compressor upgrade, intake, exhaust... could be a stout 400hp reliable truck
Old Sep 6, 2011 | 09:50 PM
theneckasaurus's Avatar
well if the trans is fully built then Id go with a full set of guages, pyro, trans, boost, and whatever else you want. 4" exhaust- depends, air intake- homemade $100, 4gsk w/ 60lbs valve springs- $226, injectors say 5x14's- $700, turbo I would disagree with the above statement of the hx40, with 5 grand you could afford say an s300- $1000-$1500, afc mods- free, plate-$20-$30, airdog or fass-$500-$700, and maybe some head studs$220? All these prices are really general. But this will definitely put you in the 400hp and over mark. 700-900 ft/lbs torque. I run pretty much a close replica of this setup and really enjoy it. But this is just me, some other veterans might chime in with a dynamite setup for alot cheaper.
