12 valve and p pump parts
Swapping a ve out for a 175 hp p7100. Currently running a phatshaft 62 (hanging an s480 under it soon). I am looking for prices for:
both timing gear case gaskets (94)
crankshaft seal
p pump case oring
new ppump nut and washer
4000 gsk
191 or sdx comp dvs
mack rack plug
fuel fittings for front feed and side feed, barbed 1/2 in (i can look up thread size if need be)
heavy duty pushrods
60 or 110 lb valve springs
2nd gen 24 valve tappets
options on aftermarket cams 181/210 (cant fly cut)
13in flywheel and ceramic clutch 600hp (nv4500)
crankshaft seal
p pump case oring
4000 gsk
191 or sdx comp dvs
mack rack plug
heavy duty pushrods
ItsAChummins
May 15, 2015 05:02 PM
btg2820
Apr 27, 2015 12:09 AM
bonestock
Feb 1, 2015 08:41 PM
