#0 Fuel Plate and boost elbow Question
Old Sep 3, 2011 | 08:53 PM
ipooted205's Avatar
Default #0 Fuel Plate and boost elbow Question
ok so i have an all stock 1995 cummins 2500, 47RH tranny. i wanted to add a #0 fuel plate with a boost elbow. what affects will this have on my truck? and what foes the boost elbow really do? and i do have a 35psi boost gauge and a 1600 E.G.T gauge.
This is the one i want to get.
Dodge Cummins Diesel Fuel Torque Plate # 0 #0 | eBay
Old Sep 3, 2011 | 09:06 PM
monster12valve's Avatar
i would just pull the plate....same thing and u get to save ur money.. the boost elbow lets less air go to the wastegate.... allowing for more boost before the wastegate opens.... just be easy on the trans....they dont like much more then stock power.
Old Sep 3, 2011 | 09:18 PM
ipooted205's Avatar
where may i find a guide to take off my plate, and if i pull it what do i put in its place? nothing?
Old Sep 5, 2011 | 09:37 AM
just take the afc off and yank the plate....thats all.
you will notice a good difference....but once u get the 4k gsk and 60lb valve springs it will be a WHOLE new truck.
Last edited by monster12valve; Sep 5, 2011 at 09:37 AM. Reason: Automerged Doublepost
Old Sep 5, 2011 | 03:12 PM
aguilar_15's Avatar
There's a sticky at the top of this section, I believe it tells you step by step how to remove the plate and everything, good luck
Old Sep 5, 2011 | 07:30 PM
o and the 47rh hates power...so a tc and vb would be the next to save for.
Old Sep 5, 2011 | 07:35 PM
turbo2332's Avatar
i would recommend a plate if you daily drive your truck. my .02
Old Sep 5, 2011 | 07:41 PM
Apmcrx's Avatar
Up
Just to clarify for the original poster....
Torque Converter & Valve Body.
Old Sep 6, 2011 | 06:06 AM
AdirondackCoalRoller's Avatar
I have seen the boost elbows and they appear to be nothin more than a brass elbow. Is this correct or is it a modified brass piece??Thanks for the help.
Old Sep 6, 2011 | 04:15 PM
turbo2332's Avatar
its a brass elbo with a set screw and a small hole in the elbow. the set screw is set to let a certain amount of air to leak through the hole and fool the wastegate on your turbo, THUS alowing the turbo to produce more boost before the wastegate can catch on PSI in its reference hose.
