Ford 2003 F350 won't start
Old Sep 2, 2011 | 08:02 PM
angel's Avatar
Default Ford 2003 F350 won't start
My truck won't start. It was working fine and I came out of Wal mart and it would not crank. It sounds like the batteries are weak so I replaced both batteries and about a month ago I changed the alternator out. That didn't work so I had the started replaced today. Still won't crank. It turns like it wants to start but its not turning fast enough to crank. anyone have any idea what could be the problem.? this is my only ride so please if anyone can help I would be so grateful
Old Sep 2, 2011 | 08:55 PM
RanchhandTCR's Avatar
It could be you crank position sensor (Hopefully) or you high pressure oil pupmp. Ford injectors run off oil pressure no pressure no start. Also if you have a bad crank sensor it wont fire because the engines has to be cranking 750 RPM to fire the injectors. Hope this helps!
Old Sep 2, 2011 | 09:02 PM
angel's Avatar
Default pls help
do you know how to check it? I have know idea where that is at. thanks hun
Old Sep 2, 2011 | 09:21 PM
cobra's Avatar
might be u need fuel pumpor injection pump cuz my dads it would sound like it wanted to fire up but wouldnt so we charged batteries cuz they were a yr old if that was the prob and nothin then he thought the injectors might have dirt in them got new injectors and put them in still nothin got new fuel pump and injection pump put fuel pump on and it worked !! It also would throw white smoke when it would try to fire up so juist tryin to help
Old Sep 2, 2011 | 09:36 PM
They only was to check the crank sensor is to replace it sadly. It located under the engin in the front left. You should see a lil probe lookin deal with wires goin into it.
That might be another thing like cobra is sayin. Have you checked you fuel filters. Ford has an inframe transfer shound be under the friver door bolted to the frame, and you should have on on top on the engine there real easy to change filters. Along when you crank it do you have any smoke coming out of the exhaust?
Last edited by RanchhandTCR; Sep 2, 2011 at 09:36 PM. Reason: Automerged Doublepost
Old Sep 2, 2011 | 09:40 PM
cobra's Avatar
yea cuz my dad hasa a cummins n he didnt know what was wrong so he did all that just need to send injection pump back cuz he didnt need it it was fuel pump
Old Sep 2, 2011 | 09:43 PM
Ive had two issus like yours there on you ford. Both on the POS 6.0L my grandfathers oil pump and another on a friends crank sensor the systems are alike just junk engines. Be glad you own a 7.3L and do me a favor dont sell it for the new one either.
Old Sep 2, 2011 | 09:44 PM
cobra's Avatar
haha
Old Sep 2, 2011 | 10:02 PM
By the cobra nice lookin truck there.
One more thing, I made the assumption since I forgot 03 is when they began to switch to the 6.0L Powerstroke Is yours a 6.0L or 7.3L if its s six litre unless you have REAL TINY hands your not gonna be able to reach that crank sensor if its a 7.3 your in good shape.
Last edited by RanchhandTCR; Sep 2, 2011 at 10:02 PM. Reason: Automerged Doublepost
Old Sep 2, 2011 | 10:17 PM
cobra's Avatar
thanks ranchand
