Dually To Single Wheel Conversion
Old Jan 5, 2008 | 08:47 PM
Default Dually To Single Wheel Conversion
Ok, fellas - I may have ran across a real good deal on a 98 Quad Cab 4X4 dually and am wondering what all is involved in a conversion to a single wheel?
Obviously, I would need to locate a long box bed. I have no idea how the duals work. Can you just take off the outer set of wheels?
Old Jan 5, 2008 | 08:49 PM
Uncle Bubba's Avatar
You just find somebod on here that wants to make their single wheel into a dually and trade em rear ends and the bed is the easiest way.
Old Jan 5, 2008 | 08:50 PM
DangerousDuramax's Avatar
What ya do is see...you go to your local dealer...OR...look through eBay or Truck Trader and you FIND A SINGLE REAR WHEEL TRUCK.
Old Jan 5, 2008 | 08:51 PM
Kind of hard to ship a bed across the border...
How do the duals work?
I know it would be much easier to swap a 1 ton to 3/4 ton rear diff and be done with it.
Old Jan 5, 2008 | 08:52 PM
Thats not what I asked ya putz...I already have two of them
DazedandConfused's Avatar
You can leave your dually rearend under the truck. The rear wheels if you put a nice set of aftermarkets on it will stick out the same as the front wheels. Put a set of fender flares all the way around on a single wheel bed and drive on. Front you just take the spaces off and put studs in for the single wheels.
Old Jan 5, 2008 | 08:54 PM
Old Jan 5, 2008 | 08:56 PM
Don't have to ship it. You all just meet up someplace with a garage and do a direct swap right on the spot. Your both back on the road the same day.
Old Jan 5, 2008 | 09:03 PM
Ok...thanks fellas - didnt think it would be too hard.
I have to call the guy yet.
Still, Im curious - what holds the outer wheel on? Ive never really looked at a dually very close.
Old Jan 5, 2008 | 09:07 PM
As I recall when I was lookin into making mine into a dually the axle is just a little narrower then the single wheel, was the answer i was getting then.
One of them IBF boys will take you up on this and they're fairly close.
