2004 24 valve cummins hard starting
Old Sep 1, 2011 | 05:12 PM
hawthorne23's Avatar
Default 2004 24 valve cummins hard starting
I have a 24 valve cummins take awhile to crank over. Some people said it would be a injector but it would smoke right??? Any ideas what could be wrong with it??
Thanks
Old Sep 6, 2011 | 03:58 PM
crazyrocks's Avatar
have you figured it out yet?
If not I had a similar issue that turned into a no start... I had no smoke at first and it ended up being a bad injector. I would start by checking my battery for a full charge, cleaning all sensors (V.C. gasket harness, map, its, ckp, and csp sensors with electrical connector cleaner) and then do a lift pump flow test.
Old Sep 8, 2011 | 08:16 PM
bullhead's Avatar
Chase your fuel down. Got full filter housing? (if not possible lift pump) Got solid rail pressure? (if weak or all over the place cp3 pump) If these are good, could be injector. Lift pump on early 04 (305 hp) is behind the filter but there was and update some dealers done and sometime when they changed to 325 hp they put them in the tank.
Also is there a check valve on the return side on the CR? I know on some large trucks do this but not sure on the 5.9
hurriedcoyte
Jun 19, 2015 06:26 AM
PeteBug
Jun 11, 2015 12:16 PM
trab123
Feb 9, 2015 09:44 AM
PerformanceAuto
Jan 15, 2015 12:32 AM
Ram700
Jan 2, 2015 08:14 PM
