whats ur rpms when running 70mph
Old Sep 1, 2011 | 04:50 PM
skyjacked84's Avatar
Default whats ur rpms when running 70mph
i just had some trans work done an mine seems to be high in the rpms going 70, and i dont remeber it being that high befor. it runs about 2400 rpms at 70-72
Old Sep 1, 2011 | 05:57 PM
BACONBITSFORU's Avatar
Thats really high... On my 2001 auto its under 2000
Old Sep 1, 2011 | 07:58 PM
dangerous1965's Avatar
About 2100rpm at 70. Do you have little tires on it "undersized"? Overdrive off does what?
Old Sep 1, 2011 | 09:37 PM
i have over sized ones. 34.5 i pulled the tunes off an it still seems alot higher than when i drove it back from NC
Old Sep 1, 2011 | 11:47 PM
MrSandman818's Avatar
With 35's it was runnin at like 1800-1900 and the speedo was dead nuts accurate. With the stock sized tires its runnin at like 2200 and the speedo's off by 5mph.
Old Sep 2, 2011 | 03:37 PM
Azdiesel's Avatar
I run 35's at 1900 rpm
Old Sep 2, 2011 | 08:35 PM
gijohn45's Avatar
I have 35 inch tires on my 01 and it runs about 1900 at 70 mph
Old Sep 5, 2011 | 02:21 PM
retread225j's Avatar
mines turning 1975 at 70 mph with 265/70r17s. sounds like overdrive is locked out. mine will turn about 2400-2500 with overdrive locked out.
Old Sep 6, 2011 | 01:10 PM
Correction, When my gps says im going 70mph my truck is running between 2300 and 2400 rpm. When the speedo says im going 70mph im running around 2150rpm. I need to get taller highway tires. I got 65k till I can get new ones
Old Sep 6, 2011 | 02:39 PM
are you rinning a tune?
