4.10 to 3.54 swap questions
Old Sep 1, 2011 | 11:29 AM
South Tx Coal Roller's Avatar
Default 4.10 to 3.54 swap questions
I have a few questions for those of you who have done this swap.
What kind of shim kit did you use and where did you get it from?
How hard was it to get a good pattern?
Did you run in to any "extras" that needed to be purchased besides a shim kit or bearings?
I'm going to be swapping in a set of used OEM Dana 3.54 gears so maybe the stock shims will already be pretty close.
Old Sep 2, 2011 | 07:31 PM
What, did everyone wuss out and actually PAY someone to install them? Lo jk!
Old Sep 4, 2011 | 06:44 PM
cumminspwr11's Avatar
i saw online somewhere a 3,54 gear ratio that came with a spacer plate so it could be used on either carrier, i wanna know how you like the 3.54s over the 4.10s when your done, i was thinking about going a bit lower than the 3.54s i have now, im just looking a bit more off the line power when im towing the hoe
Old Sep 6, 2011 | 02:23 AM
Sudia247's Avatar
Would you be interested in selling your 4.10 gears when youre done?
Old Sep 6, 2011 | 08:55 AM
Cumminspwr11, I think the spacer plate has to do with the case break of the Dana 80 axles. You can't go below 4.10 without changing the carrier or adding that plate.
Sudia247, I might. I just want to make sure I like the 3.54s first.
I guess I'm just going to order up a shim kit and see what I come up with.
Old Sep 9, 2011 | 10:33 PM
Sudia247's Avatar
Oh take your time! no hurry, I hope the install goes easy for you!
Old Sep 25, 2011 | 12:20 AM
dshane62's Avatar
i had to add 1 shim just set the backlash never had any issues
Old Sep 25, 2011 | 06:41 PM
7$crawler's Avatar
i have set up alot of gear sets and there is no set answer to your question! every gear set is a little different and thus they all need different shims. the spacer will work but a new carrier is a better choice. if i had to guess you would be makeing your pinion shalower and then moveing the carrier to the right to tightin backlash but its anybodys guess until u are in there. just make sure u get it right towing heavy loads will kill an improporly set up diff! good luck
Dieselnube
Jun 23, 2015 11:38 PM
mdub4life29
May 9, 2015 10:04 AM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
metal_miner
Dec 23, 2014 11:40 PM
Nov 12, 2014 08:10 AM
