12v p-pump in 2005 HELP!!!
Old Aug 31, 2011 | 05:40 PM
cuthbert97's Avatar
Default 12v p-pump in 2005 HELP!!!
i just intalled a 12v p-pump in my 2005 dually,
the truck used to be automatic, so i bought a g56 transmission, used clutch hydrolics and pedal.
the promblem im having is getting my clutch to activate,
ive tried lengthening the pin and the onthy thing that i can feel is vibration in the pedal.
are the hydrolics shot?
the clutch is from the 12v, but when i compared to the clutch that came with the g56 the all lined up. it all went together good.
please any help would and will be apreciated!
Old Sep 1, 2011 | 07:03 AM
K80's Avatar
K80
They are at different heights. Call Peter or someone at South Bend. They'll straighten you out. I don't believe you will have enough adjustment in the rod for it to work correctly. You will probably need the whole g56 clutch.
Old Sep 1, 2011 | 09:27 AM
Farmboy 2.0's Avatar
You need to run the third gen hydros otherwise the clutch will not engage properly.
Old Sep 1, 2011 | 11:04 AM
cuthbert97's Avatar
I have third gen hydros. And this clutch and tge g56 clutch is the same height. I put them both on a flat surface and looked.
And thanks, Malcolm at harbor city diesel told me to call Peter aswell.
I'm giving him a call today at 1:30 his time.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
Cavnar
Sep 9, 2015 07:18 PM
HardLuck
Jun 24, 2015 08:04 AM
ItsAChummins
May 15, 2015 05:02 PM
moneypitk5
Feb 12, 2015 11:01 AM
