good turbo? will it work? ''not ebay''
Old Aug 31, 2011 | 08:42 PM
blazier18's Avatar
Default good turbo? will it work? ''not ebay''
Bullseye Turbo S362 Non Extended Tip T-3 .70 A/R S362-2 BuyImportPerformance.com
or
Bullseye Turbo S360 Non Extended Tip T-3 .70 A/R S360-2 BuyImportPerformance.com
idk what to ask these people
any good ideas? anything?
Old Aug 31, 2011 | 11:22 PM
cummin_un_glued's Avatar
FormerVendor
non extended tip wheel and a non gated .70(12cm) turbine housing....not much better then your hx35 and actually more drive pressure because of the lack of the wastegate
Old Sep 1, 2011 | 01:56 PM
blazier18's Avatar
so neither of them are any count?
Old Sep 1, 2011 | 04:43 PM
FormerVendor
i'm not gonna say there no good, just that i would not run them on my trucks
Old Sep 1, 2011 | 04:49 PM
Farmboy 2.0's Avatar
How much fuel do you have? Or what are you plans for the truck?
Old Sep 2, 2011 | 12:08 AM
blazier18's Avatar
lots of fuel will be ran no plan or goal just lots of fuel just looking for a top turbo over a ht4b if it would be better then the super40
Old Sep 3, 2011 | 12:34 AM
FormerVendor
for those to work over a ht4b you would want to add an external gate then by the time you add the price of that in and a spacer with a port, it would be more cost effective to just get a different top turbo
Old Sep 3, 2011 | 01:47 AM
blazier18's Avatar
whats your idea on best top turbo dustin? a worked hx50?
Old Sep 5, 2011 | 07:45 PM
FormerVendor
i think you would be alot happier running a S362/68/14cm gated and i think you will be happy with that charger for a while and will make a nice top charger later
Old Sep 5, 2011 | 08:03 PM
blazier18's Avatar
well not to bring up junk but ebay has s362 borg warners for about 800 t3 or t4 housings 63 inducer 74 mm comp wheels and .80 ar or .77
