no talkin to v44/fault code p1689?
Old Aug 31, 2011 | 10:01 AM
72fj's Avatar
Default no talkin to v44/fault code p1689?
engine ecm or v44 control modual failur?
Old Aug 31, 2011 | 01:01 PM
Farmboy 2.0's Avatar
That would be a VP44 issue normally. But there have been a few occassions where the 1689 code can be thrown by a bad fuel pump relay in the main fuse box. If you pull this relay you can crank you truck without it starting. but it will throw the 1689 code in the ecm. But more than likely the vp is on its way out
P1689 - No Communication Between ECM and Injection Pump Module Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.
Old Aug 31, 2011 | 06:06 PM
empty wallet's Avatar
If you go to blue chip diesels website he has a great troubleshooting write up, and tells you how you can make sure 100% its your vp. Is the truck dead? If you get the 0216 code then shes cooked for sure
Old Aug 31, 2011 | 07:03 PM
72fj's Avatar
Default no talkin !
truck runs idles rpms up,burps like tps going out.had my injection pump shop fax over oem trouble shoot sheet oem wire harness its good looks like recon engine ecm installed not to long ago my little car dealer ship keeps buying these dodges from auctions stupid!!! good for me ha ha ha.but no vehicle history thanks for the input...
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
rowekmr
May 31, 2015 09:03 PM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
