6.0 question
Old Aug 30, 2011 | 03:16 PM
Lethal's Avatar
Default 6.0 question
Our 6.0 is acting up, it vibrates in idle and feels like it has hesitation when driving. If he pushes it it clears up for a little while and starts again. Also, sounds like it is missing. He said it backfired the other day. What could cause this? We replaced oil cooler, egr cooler, and cleaned exhaust pipes. We also checked egr valve, it isn't sticking open.doubledhotshottrucking@yahoo.com
Oh yeah, it doesn't show any codes.
Old Aug 31, 2011 | 10:11 AM
Mdub707's Avatar
Going to need a lot more info about the truck. How many miles? Any mods? What is the truck used for mostly? Did this start out of the blue, or has it been getting progressively worse? When you first fire it up, does it take a while before it starts? Does it smoke? What color smoke?
Any more info you can provide will help.
What did you scan it with for codes, or are you just saying it has no codes because there isn't a check engine light?
Old Aug 31, 2011 | 07:25 PM
Lethal's Avatar
It is used for a hot shot truck, has 163,376 miles. Started acting like this slowly getting worse now. Cranks right up, but as it warms up it developes engine lope. It has a small amount of black smoke when you push on gas. He used an OBDII.
Old Aug 31, 2011 | 09:13 PM
bismic1's Avatar
What year? Sounds like an ICP issue to me.
Old Sep 1, 2011 | 09:33 AM
Lethal's Avatar
where is icp, ficm, ecm, pcm on a 2006 f350 superduty (lariat) 6.0
scubasteve12
Mar 29, 2015 09:39 PM
twilks445
Mar 4, 2015 04:26 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
thumperf350
Jan 8, 2015 12:55 AM
Bigredpowerstroke
Nov 25, 2014 03:21 PM
