SPEAKER WIRING
Old Aug 30, 2011 | 02:43 PM
GOINGREEN's Avatar
Default SPEAKER WIRING
I WAS TRYING TO PUT SOME NEW 6X9'S IN THE FRONT OF THE TRUCK AND THEN I SAW THAT EACH SIDE HAS SOMETHING MOUNTED TO IT WITH 6 WIRES.....WHEN I CUT THOSE WIRES FROM THE DRIVERS SIDE THE PASSENGER SIDE QUIT WORKING....OOPS. I FIGURED THERE WOULD BE 4 WIRES 2 GOING TO THE SPEAKER AND 2 GOING BACK TO THE TWEATER BUT THERE IS 6 TOTAL??? IM LOST NOW....DOES ANYONE KNOW WHAT I SHOULD DO NOW??
Old Aug 30, 2011 | 04:20 PM
daveO's Avatar
Do you have one of the "special" sound systems. I know my Camaro with the Bose system had built in amps for the speakers. Maybe it's something like that.
Looking at the FSM, the Infinity sound system uses individual amps for the speakers and feeds through a "Radio Choke Relay." It also feeds wires up to the A-Pillar tweeters. Also, it looks as if both front speakers share a common ground, which would explain why you lost your other speaker.
Old Aug 30, 2011 | 04:40 PM
GOINGREEN's Avatar
I HAVE NO IDEA WHAT A RADIO CHOKE RELAY DOES EITHER...CRAP. WELL I WAS JUST THINKING ABOUT TAKING THAT AMPLIFIER THINGY OUT OF BOTH SIDES AND THEN WIRING THE TWEETERS UP WITH SOME BASS BLOCKERS OFF THE 6X9'S. THIS IS KIND OF WIERD BECAUSE THE TRUCK DIDNT HAVE AN INFINITY RADIO WHEN I GOT IT, MAYBE IT HAD BEEN CHANGED BEFORE....THANKS FOR THE HELP
Old Aug 30, 2011 | 07:41 PM
daveO's Avatar
Are you replacing the radio too, or is it already aftermarket?
Old Aug 31, 2011 | 12:43 PM
GOINGREEN's Avatar
yea it is an aftermarket deck.......i guess i could yank it out and just re wire the whole thing...mmm sounds like work now
Old Aug 31, 2011 | 02:28 PM
daveO's Avatar
That might be the best way to go unfortunately.
Old Aug 31, 2011 | 08:25 PM
dennhop's Avatar
Those pieces are your infiniti speaker amps. Which means you also have tweeters somewhere-I think in the 12v's, the tweeters were located higher up in the door panel. The problem with those amps is that if you cut them out of the system, you literally have to wire a whole new set of speaker wires to get your factory system to work-and your tweeters won't work anymore. The easy way to fix this, which is what I did on my old truck, is I cut the wires going from the amps to the speakers themselves, and then crimped on two new connectors to the ends, so I could just plug the amps into the new speakers. Might need to extend the wires a bit, and then ziptie the amps out of the way, inside the door. This way, with new speakers, and/or a new deck, your speaker system will work the same as factory, to include your tweeters, with minimal wiring modifications.
cumminspwr11
12
Oct 17, 2021 03:50 AM
ofelas
11
Aug 12, 2015 07:23 PM
yzrider250
Diesel Engine Conversions
Aug 10, 2015 11:33 AM
Forks diesel nut
Jul 27, 2015 12:19 PM
Mike H
Nov 25, 2014 03:13 PM
