06 5.9L Down cylinder?
Old Aug 30, 2011 | 02:38 PM
06 RAM's Avatar
Default 06 5.9L Down cylinder?
When you take off the oil cap there is an inordinate amount of back pressure. I was told by one mechanic that it must be a broken ring. Also it is idling rough and there is alot of crankcase pressure venting through the tube. Is there anything else that would cause this?
180,000 miles.
Old Sep 9, 2011 | 12:33 PM
cumminspwrram59's Avatar
my 05 did the same thing tore it down and i had 2 cylinders with broken rings. after rebuild with all new pistons, rings, etc. i still have the exact same amount of blow-by.
Old Sep 9, 2011 | 12:38 PM
Kraemer's Avatar
there are blow by meters to determine just how much is too much...
Old Sep 12, 2011 | 03:00 PM
06 RAM's Avatar
Ihave also used 1 - 2 quarts of oil in 1000 miles.
jbxyz
Chevy/GMC Duramax 01-04 LB7
10
Apr 24, 2015 07:19 PM
Kennyw250
Jan 14, 2015 07:47 PM
Oct 31, 2014 08:10 AM
Omingnome
Oct 20, 2014 12:25 PM
91 7three
Oct 15, 2014 12:57 PM
