Brakes
Old Aug 30, 2011 | 01:49 PM
South Tx Coal Roller's Avatar
Default Brakes
I just replaced the front and rear brakes and now when I pump them up the pedal gets hard but barely stops the truck. Just hitting them normal the truck stops fine. I don't think I have a vacuum leak, maybe the vacuum pump is weak?
Old Aug 30, 2011 | 03:45 PM
aguilar_15's Avatar
Did your bleed your lines out? Could have air in them if your disconnected the lines.
Old Aug 30, 2011 | 04:22 PM
Didn't disconnected the lines. I'm starting to think that there might be trash in the lines. I'll probably try to flush all the old fluid out of the brake system while adding fresh fluid in the reservoir.
Old Aug 30, 2011 | 09:44 PM
aguilar_15's Avatar
Yea that might work, did that on an old p/u I had, worked like a charm. Clean out the reservoir first with a clean shop rag or something though, get all the dirt an crap outta there.
Old Sep 1, 2011 | 03:27 PM
sjcoan's Avatar
It wouldn't be a vacuum leak these diesel trucks use the power steering pump for the brake booster.
Old Sep 1, 2011 | 04:22 PM
kawgomoo's Avatar
Negative. 96's have vacuum operated power brake booster. 97s up have hydroboost.
ask how i know.
Old Sep 1, 2011 | 09:01 PM
sjcoan's Avatar
My bad, sorry about that had no idea they were different I retract my previous statement.
Old Sep 1, 2011 | 10:30 PM
kawgomoo's Avatar
LOL..its all good. caught me by surprise too.
pretty much, from what i can tell. is if you have a 2nd gen ctd, and a 47rh trans it got vacuum brakes.
if you have the 47re, it has hydroboost.
lots of mix matching went on in those first few transitional years.
Old Sep 2, 2011 | 07:27 PM
I have a 47RE with vacuum brakes. Still not sure whether I like the vacuum or hydro better.
The brakes have gotten a LOT better now but I'm still going to bleed them out good this weekend. They are still a little too soft so hopefully that will fix them.
DC_DC41
Jul 16, 2015 09:56 PM
Radioking1777
Jun 9, 2015 04:13 AM
Jun 8, 2015 07:10 AM
thatdude38
May 9, 2015 12:21 PM
kryz9903
May 4, 2015 05:00 AM
