New Member, Got a Question
Old Aug 30, 2011 | 07:52 AM
jen72830's Avatar
Default New Member, Got a Question
Thanks for the info I have a question but not sure just where to go to ask on this site, new here.
I got stuck on the side of the road. Going down interstate, my truck had the "dead pedal" for a few seconds, I got off interstate, and the pedal started working right, about 15 minutes later, my truck died and would not start back up? Do you have any suggestions for that? My friends seem to think that it is the injectors? But there was no smoke coming out. Any advice please
Old Aug 30, 2011 | 10:34 AM
wildbill's Avatar
Sounds like your lift pump went. Is it in the fuel tank??
Old Aug 30, 2011 | 10:36 AM
Has he checked the fuel filter?
Old Aug 30, 2011 | 02:26 PM
vinnie0104's Avatar
i had the same thing happen to my 04. my lift pump was burnt. i just replaced it with a FASS lift pump and was good to go.
Old Sep 12, 2011 | 09:11 AM
roaddog51's Avatar
Was just wondering at what milage did the pump go out or was that even the proublem??
Old Sep 15, 2011 | 07:58 AM
vinnie0104's Avatar
Mine went out at around 94k. I have read alot about OEM dodge lift pumps having alot of problems. And figured it was due time. Im sure the amount of use and wear and tear on the vehicle would play a part.
Old Sep 15, 2011 | 09:58 AM
dangerous1965's Avatar
Clean your battery terminals just for kicks! Put a guage inline to see if you have fuel pressure the CP3 will pull fuel past the pump so a no start may be that or something else.
Any codes?
Old Sep 16, 2011 | 02:05 PM
brentm@fassride.com's Avatar
Same thing happened to my 99 cummins. Those carter lift pumps are junk. Replace it with a FASS DDRP which is like a 45 minute install or get a full system... Fass - Fuel Air Separation System
Melman
Jun 16, 2015 03:32 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Regcabguy
Jan 21, 2015 09:28 PM
countryboy040993
Dec 31, 2014 05:10 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
