Edge Juice
Old Jan 5, 2008 | 10:54 AM
Horse Power's Avatar
Default Edge Juice
When my box is on and I am accelerating it feels like the box is shutting off and on(the lights on the box stay on). It seems like something is shorting out because the Edge Box power keeps going off and on. Has anybody had this problem or have any suggestions on how to correct it? I checked all the wires and plug connectors and everything seems to be fine.
Old Jan 5, 2008 | 11:09 AM
Benjamin's Avatar
Bombardier
i had the same problem.... it kind of for a lack of better words "studders" just not real fast. we ended up sending it back to Edge and they replaced it.... i hope this helps.... check also on the box under the hood on one of the sides there are some green LED's that'll be randomly blinking if the correct pump wire is tapped.... there should be a better explanation in the installation/troubleshooting manual than that....
Old Jan 5, 2008 | 12:06 PM
Lostnwalmart's Avatar
with my redline i had a bad connection with the pump and it didnt really studder more jolted and eventual kill the truck turned it off and it ran jsut fine.... didnt read if u had tryed it with the chip off or not, also check fuel filter if it hasent been changed in a while or u filled up at your non normal fuel stop.
Old Jan 5, 2008 | 12:09 PM
Try running the power wire on the Edge straight to the battery
Old Jan 5, 2008 | 08:27 PM
When the box is off it runs fine, Like a stock Dodge. I only have one box inside the truck with the wires going out to the plugs.
Old Jan 5, 2008 | 08:30 PM
Is the power ran straight to the battery?
Old Jan 5, 2008 | 08:36 PM
No i did not try that yet. I will tomorrow. Oh and when you trun the key on The box does not come on , you have to trun the key off then back on. Some time i have to do that 1 or 2 times.
Old Jan 6, 2008 | 02:40 AM
2500HeavyDuty's Avatar
If your lucky its just a bad power connection, let us know how that turns out
Old Jan 6, 2008 | 11:02 AM
Well I hooked up the power stright to the batt The box came on full power and stayed that way. I could not trun the power down or trun the box off.( on with full power)
Old Jan 6, 2008 | 11:09 AM
Whit's Avatar
Site Mascot
well ya found the problem....cool
I would get it hooked up to a good fusable power supply now............you dont wanna keep it to the battery unless ya do a inline fuse for it
