Pulling/overheating Problem
Old Aug 29, 2011 | 12:51 PM
littlpa's Avatar
Default Pulling/overheating Problem
Hi
I have 02 Duramax 2500 HD 6.6, went camping with the 5th wheel and started to have overheating issues when climbing hills or bucking the wind. I am able to keep if under control by lowering my speed and babying the truck. When I stop it starts to leak coolant near the back on the passenger side where the tranny & engine connect.
When i am not pulling the truck runs perfectly fine, no overheating or leaking coolant.
Might this be a gasket issue due to the pressure from the turbo?
Any help would greatly appreicated!
Pat
Old Aug 29, 2011 | 06:40 PM
cfarley0210's Avatar
Is this the first time u have towed with this or is it a new broblem? Is there any coolant in the oil? Does ur fan kick on when it gets worm? The coolant coming out behind the motor worries me. But its only when its towing which is weird. I would say check the oil, the fan, and make sure u have coolant and its flowing, stuck thirmostat.
Old Aug 30, 2011 | 01:46 PM
littlpa's Avatar
No, i have been towing with it for the past 6 years. Have not checked the oil yet for coolant, yes the fan does kick in, coolant is good for right now unless I am towing then i will lose some due to the leak.
Old Aug 30, 2011 | 08:03 PM
BriteWhiteRam's Avatar
could be a bad head gasket
Old Aug 31, 2011 | 02:23 PM
I would say it probably has a blown head gasget if the coolant is leakin out the back of the motor. It sounds like when its under a load building lots more boost than normal driving conditions it picks the head up a little bit
Old Sep 1, 2011 | 01:20 PM
nsolimini's Avatar
Head gasket would be my guess too
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
thurobred1320
May 5, 2015 09:26 PM
Dadslb7
Dec 9, 2014 11:05 PM
