HOAT coolant??
Old Aug 29, 2011 | 08:06 AM
GWDriver's Avatar
Default HOAT coolant??
Ok, I'm dumber than dumb I guess. I've never heard of HOAT coolant until I had to change my waterpump. Seems a bit early for that type of failure, but what do I know??
Checked my owners manual and tech manual and it mentions the HOAT coolant in a 50/50 mix with distilled water as the preferred coolant for my truck. I can see the distilled water, BUT is Dodge coolant recommendation the only coolant that is acceptable for the '03 Cummins or is it just that it is the best for the engine.
Aren't there other coolants for diesel engines that would work just as well and have the same protection properties??
Thanks for any feed back.
Old Aug 29, 2011 | 05:54 PM
coors_man_2005's Avatar
i just run prestone 50/50
Old Aug 29, 2011 | 11:36 PM
GWDriver's Avatar
Hhmmmmmmm.........................
I thought Prestone was a propylene glycol. Or do they also make an ethylene glycol. What color is the correct antifreeze?? Green?? Pink??
Old Aug 29, 2011 | 11:39 PM
in my 08 was pink but now is green i wouldnt think it could be that much different but i have always thought antifreez is antifreeze does one cool better then the other ??
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
